on pc when I select default dashboard, I retain access to the Overview tab in the sidebar. On android doing the same removes the tab. I would like to retain access to this tab on android as well without it being the 1st tab I see. I only found this topic with no replies Overview dashboard disappear.
this is HA frontend behavior, the app does not control it. Have you tried editing the sidebar once you set the default dashboard to see if you can add back Overview?
Apologies if I misunderstand, but if it was the default behaviour it would do what I want.
on pc:
open ha 1st time see Overview
change to different default dashboard
open HA again, see the chosen dashboard, with Overview still in sidebar
on android:
open HA again, see the chosen dashboard, Overview disappeared from sidebar
Where would I edit the sidebar? The only thing related to sidebar I found is an option Show in sidebar for every custom dashboard, however it is not present for Overview dashboard.
may want to check open frontend issues as the app does not control that list. You can do a quick test too by checking the side bar using chrome for android on teh same device, most likely will look the same.
As advised in the github thread there is apparently an undocumented feature, that auto fills empty dashboard with w/e would be in Overview. I tested it on Android and it works.
Add new dashboard, name it and do not do anything else with it.
Then visit it via sidebar and it will show what would be in Overview tab.
I did find a cumbersome workaround: On any dashboard > Menu > Edit Dashboard > Menu > Manage Dashboards > Open the Overview dashboard by clicking the pop-out button.
If it’s a feature than there should be a toggle somewhere to disable it. I want my Home Control dashboard as default but still have access to the Overview. The Overview is awesome since it adds new stuff automatically and has the entire system in one place. Took getting use to but I’ve grown to like it.
I’m not a programmer but wish I was because I hate changes to a UI once gotten use to. I’m a hardware person.
Thank you for your awesome Automaton Hub. The more I read the more I see everything is possible. Your only limited by your imagination unless you use mobile apps, than your limited by material design programmers.
+1 For Adding a dashboard called Overview, there is an option for adding a UI Controlled dashboard and it seams to be about the same. Will keep trying it.
It organized things a little different, I’m assuming because things were added in the order they were detected when the original was built but this time all devices were already there.
So, it’s still posable with the original workaround or with the ability of creating a UI Controlled dashboard with whatever name you want it can be called the main stream way of doing it, I guess.
This is a little bit bonkers. The idea that because you want to see a different screen first that you lose another one forever - it makes no sense whatsoever.
I was able to see all of my tabs by setting subview to false on the main Overview tab. I did this in the “Raw Configurator Editor” that is found in the triple dot menu in the top right when you enable edit mode
