has anyone done anything with the owntracks http mode? Apparently they will now post a message to your server instead of using MQTT.
I would also like to know this, haven’t had the time to investigate the http output yet but I am stuck with the embedded MQTT-client (at least for now) so I can’t use Owntracks at the moment.
There should be a way to “listen” to http-messages in HA right?
Just in case either of you haven’t seen it https://home-assistant.io/components/device_tracker.owntracks_http/
