Package setup failed
Invalid configuation after trying to add packages with separate folder to config file.
Errors when trying to control config:
Package XX setup failed. Component XX Integration 'XX' not found.
File outline:
Config
| - - packages
|     | - - package_yaml_file.yaml
|     | - - another_package.yaml
| - - configuration.yaml
Configuration file:
homeassistant:
  # Load packages
  packages: !include_dir_named packages
One complete packages file:
my_trigger_package:
  has_date: true
  has_time: true
Any help would be much appreciated!
Found the solution.
The package file must include input type like:
input_datetime:
  my_trigger_package:
    has_date: true
    has_time: true
or similar for input_boolean or input_number.
