Package Setup with Command_line Switch - error
Trying to create a package for my Playstation 4 setup
playstation_package:
  shell_command:
      ## https://github.com/dhleong/ps4-waker/wiki ##
    playstationvue_start: "ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997; sudo ps4-waker -c /config/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997 start CUSA00960"
    playstationplex_start: "ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997; sudo ps4-waker -c /config/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997 start CUSA01850"
    playstationyoutube_start: "ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997; sudo ps4-waker -c /config/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997 start CUSA01015"
    playstationnetflix_start: "ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997; sudo ps4-waker -c /config/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.66 --bind-port 997 start CUSA00129"
    - platform: command_line
      command: ps4-waker search | grep -w "running-app-name" | cut -c 24- | rev | cut -c 3-  | rev | sed 's/[!@#\$%^&*(®)™]//g'
      scan_interval: 10
  switch:
    switches:
      playstation4:
        command_on: 'ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.184 --bind-port 997'
        command_off: 'ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.184 --bind-port 997 standby'
        command_state: 'nc -z -w 5 192.168.1.184 997'
        friendly_name: "Playstation 4"
  input_select:
    playstation4app:
      name: App Selection
      options:
       - "-- Select --"
       - "Netflix"
       - "Plex"
       - "Vue"
       - "Youtube"
      initial: "-- Select --"
      icon: mdi:apps
  group:
    playstation:
      entities:
        - switch.playstation4
        - input_select.playstation4app
        - sensor.current_game
And it doesn’t like my switch configuration. It appears to setup ok, but throws the following errors.
17-04-17 12:03:00 ERROR (MainThread) [homeassistant.components] Testing configuration at /config
17-04-17 12:02:59 ERROR (MainThread) [homeassistant.config] Invalid config for [switch]: required key not provided @ data['platform']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/switch/
Failed config
  switch:
      switches: [source /config/includes/packages/playstation4.yaml:18]
        playstation4: [source /config/includes/packages/playstation4.yaml:19]
          command_off: ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.184 --bind-port 997 standby
          command_on: ps4-waker -c /config/custom_scripts/ps4-waker/.ps4-wake.credentials.json -b 192.168.1.188 -d 192.168.1.184 --bind-port 997
          command_state: nc -z -w 5 192.168.1.184 997
          friendly_name: Playstation 4
Successful config (partial)
  switch:
      switches: ?
        playstation4: ?
Any thoughts?
Try changing that single quote 'ps4-waker to double quotes
:stuck_out_tongue_winking_eye:
Hmm, doesn’t fix it.
I have the same problem. On 0.79.3
switch:
    switches:
      guest_wifi_control:
        friendly_name: Guest wifi
        command_on: 'python3 /home/homeassistant/.homeassistant/scripts/guest_wifi.py on'
        command_off: 'python3 /home/homeassistant/.homeassistant/scripts/guest_wifi.py off'
Getting the same error:
