Hi all,
I am trying to update the Panasonic Viera Component to work with panasonic_viera=0.4.3 because 0.4.2 does not have support for encrypted TV. But if I run the code inside HomeAssistant I get the following error:
de gen. 13 18:36:29 raspberrypi hass[26388]: 2020-01-13 18:36:29 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.1668440368] HTTP Error 500: Internal Server Error
de gen. 13 18:36:29 raspberrypi hass[26388]: Traceback (most recent call last):
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/websocket_api/commands.py", line 133, in handle_call_service
de gen. 13 18:36:29 raspberrypi hass[26388]: connection.context(msg),
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1235, in async_call
de gen. 13 18:36:29 raspberrypi hass[26388]: await asyncio.shield(self._execute_service(handler, service_call))
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/core.py", line 1260, in _execute_service
de gen. 13 18:36:29 raspberrypi hass[26388]: await handler.func(service_call)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_component.py", line 205, in handle_service
de gen. 13 18:36:29 raspberrypi hass[26388]: self._platforms.values(), func, call, service_name, required_features
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 336, in entity_service_call
de gen. 13 18:36:29 raspberrypi hass[26388]: future.result() # pop exception if have
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/service.py", line 358, in _handle_service_platform_call
de gen. 13 18:36:29 raspberrypi hass[26388]: await getattr(entity, func)(**data)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
de gen. 13 18:36:29 raspberrypi hass[26388]: result = self.fn(*self.args, **self.kwargs)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/panasonic_viera/media_player.py", line 190, in turn_off
de gen. 13 18:36:29 raspberrypi hass[26388]: self._state = STATE_OFF
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/panasonic_viera/__init__.py", line 554, in turn_off
de gen. 13 18:36:29 raspberrypi hass[26388]: self.send_key(Keys.power)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/panasonic_viera/__init__.py", line 538, in send_key
de gen. 13 18:36:29 raspberrypi hass[26388]: 'X_SendKey', params)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/panasonic_viera/__init__.py", line 242, in soap_request
de gen. 13 18:36:29 raspberrypi hass[26388]: raise e # Pass to the next handler
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/srv/homeassistant/lib/python3.7/site-packages/panasonic_viera/__init__.py", line 238, in soap_request
de gen. 13 18:36:29 raspberrypi hass[26388]: res = urlopen(req, timeout=5).read()
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/usr/lib/python3.7/urllib/request.py", line 222, in urlopen
de gen. 13 18:36:29 raspberrypi hass[26388]: return opener.open(url, data, timeout)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/usr/lib/python3.7/urllib/request.py", line 531, in open
de gen. 13 18:36:29 raspberrypi hass[26388]: response = meth(req, response)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/usr/lib/python3.7/urllib/request.py", line 641, in http_response
de gen. 13 18:36:29 raspberrypi hass[26388]: 'http', request, response, code, msg, hdrs)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/usr/lib/python3.7/urllib/request.py", line 569, in error
de gen. 13 18:36:29 raspberrypi hass[26388]: return self._call_chain(*args)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/usr/lib/python3.7/urllib/request.py", line 503, in _call_chain
de gen. 13 18:36:29 raspberrypi hass[26388]: result = func(*args)
de gen. 13 18:36:29 raspberrypi hass[26388]: File "/usr/lib/python3.7/urllib/request.py", line 649, in http_error_default
de gen. 13 18:36:29 raspberrypi hass[26388]: raise HTTPError(req.full_url, code, msg, hdrs, fp)
de gen. 13 18:36:29 raspberrypi hass[26388]: urllib.error.HTTPError: HTTP Error 500: Internal Server Error
but if I run the code the component is running outside homeassistant:
import panasonic_viera
rc = panasonic_viera.RemoteControl("<HOST>", app_id="BSkeeKuuwakd9Q==", encryption_key="EarvNQodKYlj5zTEIhZoXQ==")
# We can now start communicating with our TV
rc.turn_off()
everything works as expected and TV turns off.
Any knowledge why inside home assistant I get the error? It works only with the first command I run. After that any command raised the error mentioned above
PD: component is edited as expected and loads app_id and encryption_key:
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
vol.Required(CONF_HOST): cv.string,
vol.Optional(CONF_MAC): cv.string,
vol.Optional(
CONF_BROADCAST_ADDRESS, default=DEFAULT_BROADCAST_ADDRESS
): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_PORT, default=DEFAULT_PORT): cv.port,
vol.Optional(CONF_APP_POWER, default=DEFAULT_APP_POWER): cv.boolean,
vol.Optional(CONF_APP_ID): cv.string,
vol.Optional(CONF_ENCRYPTION_KEY): cv.string
def setup_platform(hass, config, add_entities, discovery_info=None):
"""Set up the Panasonic Viera TV platform."""
mac = config.get(CONF_MAC)
broadcast = config.get(CONF_BROADCAST_ADDRESS)
name = config.get(CONF_NAME)
port = config.get(CONF_PORT)
app_power = config.get(CONF_APP_POWER)
app_id = config.get(CONF_APP_ID, None)
encryption_key = config.get(CONF_ENCRYPTION_KEY, None)
if discovery_info:
_LOGGER.debug("%s", discovery_info)
name = discovery_info.get("name")
host = discovery_info.get("host")
port = discovery_info.get("port")
udn = discovery_info.get("udn")
if udn and udn.startswith("uuid:"):
uuid = udn[len("uuid:") :]
else:
uuid = None
remote = RemoteControl(host, port)
add_entities([PanasonicVieraTVDevice(mac, name, remote, host, app_power, uuid)])
return True
host = config.get(CONF_HOST)
remote = RemoteControl(host, port, app_id=app_id, encryption_key=encryption_key)
add_entities(
[PanasonicVieraTVDevice(mac, name, remote, host, broadcast, app_power)]
return True
Thanks,
ttecles
