Parse Json data into sensor
i want to update a device_tracker by sending an mqtt message with the location and using the device_tracker.see service.
My Problem is how to send the data as a variable in the node:
This is the mqtt message in Json format
{“acc”:20,“batt”:51,“conn”:“w”,“lat”:47.1555555,“lon”:7.255555,“tst”:1496413492}
and here i Need to get the lat and lon data into the node
{“dev_id”:“giannis_giannis”,“location_name”:“home”,“gps”:[“lon”,“lon”]}
However the variables are not getting through. What am i missing?
If you need help with Node-Red, you should provide you flow, it will help
anyway shooting in the dark here
assuming
is your payload
have you tried
{“dev_id”:“giannis_giannis”,“location_name”:“home”,“gps”:[“{{payload.lat}}”,“{{payload.lon}}”]}
Thx that worked
bulls eye
down to the pub to play darts !
