Parse JSON from REST sensor
I have created a REST sensor that saves this date in the sensor state.
            "StatusCode": 0,
            "Message": null,
            "ExecutionTime": 95,
            "ResponseData": {
                "LatestUpdate": "2017-08-24T14:05:39",
                "DataAge": 33,
                "Metros": [],
                "Buses": [
                        "GroupOfLine": null,
                        "TransportMode": "BUS",
                        "LineNumber": "828",
                        "Destination": "Farsta centrum",
                        "JourneyDirection": 2,
                        "StopAreaName": "Odonbacken",
                        "StopAreaNumber": 70874,
                        "StopPointNumber": 70874,
                        "StopPointDesignation": null,
                        "TimeTabledDateTime": "2017-08-24T14:10:31",
                        "ExpectedDateTime": "2017-08-24T14:11:40",
                        "DisplayTime": "5 min",
                        "JourneyNumber": 36,
                        "Deviations": null
                        "Destination": "Östra Skogås",
                        "JourneyDirection": 1,
                        "StopPointNumber": 70875,
                        "TimeTabledDateTime": "2017-08-24T14:19:32",
                        "ExpectedDateTime": "2017-08-24T14:19:32",
                        "DisplayTime": "13 min",
                        "JourneyNumber": 33,
                        "Deviations": null
                        "LineNumber": "831",
                        "TimeTabledDateTime": "2017-08-24T14:25:31",
                        "ExpectedDateTime": "2017-08-24T14:25:31",
                        "DisplayTime": "14:25",
                        "JourneyNumber": 40,
                        "Deviations": null
                        "Destination": "Länna industriområde",
                        "TimeTabledDateTime": "2017-08-24T14:34:32",
                        "ExpectedDateTime": "2017-08-24T14:34:32",
                        "DisplayTime": "28 min",
                        "JourneyNumber": 37,
                        "Deviations": null
                        "TimeTabledDateTime": "2017-08-24T14:40:31",
                        "ExpectedDateTime": "2017-08-24T14:40:31",
                        "DisplayTime": "14:40",
                        "JourneyNumber": 38,
                        "Deviations": null
                        "TimeTabledDateTime": "2017-08-24T14:49:32",
                        "ExpectedDateTime": "2017-08-24T14:49:32",
                        "DisplayTime": "14:49",
                        "JourneyNumber": 35,
                        "Deviations": null
                "Trains": [],
                "Trams": [],
                "Ships": [],
                "StopPointDeviations": []
I try to parse this date in a template with
{% set sl = states.sensor.sl_odonbacken.state %}
{{sl.StatusCode}}
I get a blank. If I look at {{sl}} it shows the json object.
If I paste the JSON from the sensor state and run this code
{% set sl ={
        "StatusCode": 0,
        "Message": null,
        "ResponseData": {
            "DataAge": 33,
            "Metros": [],
            "Buses": [
                    "Deviations": null
                    "Deviations": null
                    "Deviations": null
                    "Deviations": null
                    "Deviations": null
                    "Deviations": null
            "Trains": [],
            "Trams": [],
            "Ships": [],
{{sl.StatusCode}}
I can extract any value from the object.
There is no problem accessing the sensor attributes.
I have a feeling that the issue is caused by this code in the REST sensor
self.data = response.text
It appears that state data is being stored as text, rather than a json object.
Is there any way of parsing JSON that is stored in an entities state field?
Hi @raymccarthy, i testet the same with a file sensor, but no luck.
Wanted to use multiple values from one sensor as values for delays, input_slider, …
I gave up on this.
