Everything on this Automation is working perfectly, except for the closed door automation. The trigger is working, but it is NOT turning the light off when I close the door. The sensor is reading the data, when viewing it in live conditions the trigger is being triggered. Only problem is that the automation to turn the light off when the door is closed, isn’t firing???
alias: Living Room - Liquor Cabinet
description: Turn Liquor cabinet lights on with sunset and off with time
triggers:
- event: sunset
offset: "+00:00:00"
trigger: sun
- type: opened
device_id: 1f5f59b258e7248fde674b922b5b06bf
entity_id: faf8a9132d7104a10b87019fcd12a2bb
domain: binary_sensor
trigger: device
- type: not_opened
trigger: device
- trigger: time
at: "23:01:00"
weekday:
- sun
- mon
- tue
- wed
- thu
- fri
- sat
id: Turn Off days
conditions:
- condition: state
entity_id: input_boolean.automations_kill_switch
state: "off"
actions:
- choose:
- conditions:
- condition: template
value_template: "{{ (2,7) <= (now().month, now().day) <= (2,14) }}"
alias: February Template
- condition: trigger
id:
- Turn On
- Door Open
sequence:
- data: {}
entity_id:
- light.wled_liquor
action: light.turn_on
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- data:
option: Valentine
entity_id:
- select.wled_liquor_preset
action: select.select_option
- conditions:
value_template: "{{ (3,10) <= (now().month, now().day) <= (3,17) }}"
alias: St Patrick Day Template
id:
- Turn On
- Door Open
sequence:
- data:
color_name: green
entity_id:
- light.wled_liquor
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- action: select.select_option
metadata: {}
option: St Pats Day
entity_id: select.wled_liquor_preset
- conditions:
value_template: "{{ (7,1) <= (now().month, now().day) <= (7,4) }}"
alias: July Template
id:
- Turn On
- Door Open
sequence:
- data:
effect: Fireworks 1D
entity_id:
- light.wled_liquor
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
metadata: {}
option: Us flag Colorloop
- conditions:
value_template: "{{ (10,1) <= (now().month, now().day) <= (11,1) }}"
alias: October Template
id:
- Turn On
- Door Open
sequence:
- data: {}
entity_id:
- light.wled_liquor
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
metadata: {}
option: |
{{ ['Halloween', 'Halloween2', 'Halloween3' ] | random }}
- conditions:
value_template: "{{ (11,2) <= (now().month, now().day) <= (11,30) }}"
alias: November Template
id:
- Turn On
- Door Open
sequence:
- data:
effect: Halloween
entity_id:
- light.wled_liquor
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
metadata: {}
option: >
{{ ['Candy2 Palette', 'Orange Dancing', 'Yellow Fireworks 1D',
'Fall Flow' ] | random }}
- conditions:
value_template: "{{ (12,1) <= (now().month, now().day) <= (12,31) }}"
alias: December Template
id:
- Turn On
- Door Open
sequence:
- data: {}
entity_id:
- light.wled_liquor
- delay:
hours: 0
minutes: 0
seconds: 30
milliseconds: 0
- data:
option: Christmas
entity_id:
- conditions:
id:
- Turn Off days
sequence:
- data: {}
action: light.turn_off
entity_id: light.wled_liquor
- conditions:
id:
- Closed
sequence:
- action: light.turn_off
metadata: {}
data: {}
default:
- data: {}
metadata: {}
option: "{{ state_attr('select.wled_liquor_preset','options') | random }}"
mode: single
Thanks, because it is in the month of November it is not allowing it to see the other option of the door closing. Any suggestions? This just got complicated… Maybe a separate automation?
Confirmed, it works in a separate automation because of the date.
Here is the separate automation. Anything to combine these?
alias: Living Room - Liquor Cabinet Close
triggers:
- trigger: state
entity_id:
- binary_sensor.liquor_cab_door_opening
- "on"
to:
- "off"
conditions:
- condition: state
state: "off"
- condition: or
conditions:
- condition: sun
before: sunset
- condition: time
after: "23:00:00"
actions:
metadata: {}
data: {}
mode: single
That shouldn’t be an issue… what’s more likely is the automation mode should be changed. While you’re at it there are a few thing you can do to make the automation more efficient and, maybe, more responsive:
Thanks for that, just did the testing and it is working. It is a bit of a delayed response for the lights to turn off but using the traces it confirms of going down that branch. Appreciate the advice! That is a lot cleaner.
If the test is opening then closing the door, you might be able to make that case a little snappier by changing the mode to restart instead of the queued that I used. This will allow the “closing” trigger to break out of the running “turn on” actions and delays.
