Pass User into Script Data
I am working on a chore card for the house and am using a generic script in order to do so. I have completion of the chore working, but am having a hard time getting the {{user}} field from the lovelace UI to pass the normal value we would expect to see. Instead, it is passing the actual string “{{user}}” and moving that into the field I have to show who completed it. Does anyone know how to get the active user passed into a scripts service data? Also, pardon the not so great yaml. I’m still learning.
Script Call:
type: custom:mushroom-entity-card
icon: mdi:trash-can-outline
fill_container: false
tap_action:
  action: perform-action
  perform_action: script.1747947032739
    chore_entity: input_boolean.chore_trash
    input_select_chore: input_select.chore_trash_completer
    user_run: "{{user}}"
  target: {}
primary_info: name
secondary_info: state
hold_action:
  action: none
double_tap_action:
  action: none
name: Chore -Take Out Trash
Script Configuration:
sequence:
  - if:
      - condition: template
        value_template: "{{is_state('chore_entity','off')}}"
    then:
      - action: input_boolean.toggle
        metadata: {}
        data: {}
          entity_id: "{{chore_entity}}"
      - action: input_select.set_value
        metadata: {}
          option: "{{user_run}}"
          entity_id: "{{input_select_chore}}"
alias: Chore Completion
icon: mdi:broom
mode: single
description: ""
fields:
  user_run:
    selector:
      template: {}
    default: ""
    required: true
  chore_entity:
    selector:
      entity: {}
    required: true
  input_select_chore:
    selector:
      entity: {}
    required: true
Templates are rarely supported in card actions… even in cards like Mushroom that support templates for other parts of their configuration.
I don’t think you need to pass user as data at all.
When a script is run, context.user_id will contain the triggering user’s ID.
