Passing CC2531 USB Device Causes High CPU in VM
I’m running unRAID and using KVM as the hypervisor. I need to pass the following device to a Hass OS VM (Home Assistant):
“Texas Instruments TI CC2531 USB CDC (0451:16a8)”
The device is a USB CC2531 dongle flashed with zigbee2mqtt firmware which the VM sees as /dev/ttyACM0.
Is sees the device but cpu a lot higher than without the dongle. Without the dongle passed the qemu-system-x86 process for this VM consumes approx 25% cpu, when attached to the VM the cpu rises to 150%.
I know this sounds more like a hypervisor issue but any thoughts here from others would be appreciated.
I really don’t have any pertinenent logs or any. I’m on 6.8 stable and the VM is using Q35-2.11.
Any advice thoughts here will be greatly appreciated.
