I hope there are any clever folks who can help me out.
I am trying to manipulate the values on the X-Axis of an Apexchart. I am using the config-template-card to define a variable. See below:
type: custom:config-template-card
variables:
offset: states['sensor.solar_sun_travel_time'].state
entities:
- sensor.solar_sun_travel_time
I can use the variable ‘offset’ perfectly in for example the offset parameter of the Y-Axis.
But for the X-Axis I like to pass the value of the variable ‘offset’ to the javascript function ‘formatter’. Including ${offset} in the javascript function doesn’t work, also not as an argument in the function call.
Any idea how I can assign the ‘offset’ variable value to the ‘offsethours’ variable in the javascript function as shown below?
xaxis:
labels:
formatter: |
EVAL:
function (val) {
var offsethours=81;
datum = new Date(val);
datum.setHours(datum.getHours()-offsethours );
month = datum.toLocaleString('default', { month: 'short' });
val = datum.getDate()+ " " + month;
return val;
