Passing delay to trigger node. Need to swap minute into milliseconds
To pass a specific delay to a trigger node, you can inject a number using msg.delay but it only accepts milliseconds.
How can I convert the value in my input number from minutes to milliseconds so I can pass it into the trigger node?
[{"id":"08cfac5d89033ba3","type":"tab","label":"Flow 3","disabled":false,"info":"","env":[]},{"id":"cc1a8aca6d00ceda","type":"api-current-state","z":"08cfac5d89033ba3","name":"Input number in minutes","server":"ab3e2c53.e3491","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_number.sprinkler_timer","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"delay","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":415,"y":210,"wires":[["511c1ad3034658f6"]]},{"id":"c0c61c9d585582d1","type":"inject","z":"08cfac5d89033ba3","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":185,"y":210,"wires":[["cc1a8aca6d00ceda"]]},{"id":"511c1ad3034658f6","type":"trigger","z":"08cfac5d89033ba3","name":"trigger","op1":"","op2":"0","op1type":"nul","op2type":"str","duration":"250","extend":false,"overrideDelay":true,"units":"ms","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":625,"y":210,"wires":[["e98695fc06970b5d"]]},{"id":"e98695fc06970b5d","type":"debug","z":"08cfac5d89033ba3","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":790,"y":210,"wires":[]},{"id":"ab3e2c53.e3491","type":"server","name":"AvilaSmartHome","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
Multiply by 60,000.
Yeah but how do I write/code that in? Im assuming json but i cant write crap.
Figured it out. Using a function node
You can do it directly from the current-state node using output properties.
$number($entity().state) * 60000
I like the simplification. Thanks @Kermit
