I’m trying to clean up my config and would like to be able to pass arguments from an entity-button to a shell command. Is that even possible?
This is my current config
ui-lovelace.yaml
- type: entity-button
icon: mdi:numeric-4-circle-outline
tap_action:
action: call-service
service: script.music_inp
service_data:
entity_id: script.music_inp
zone: "02"
entity: script.music_inp
scripts.yaml
music_inp:
sequence:
- service: shell_command.music_on
data_template:
# zon: "02" <- this works with the shell command
zon: "{{ zone }}"
configuration.yaml:
shell_command:
music_on: /srv/breathe/breathe_on.php {{ zon }}
And it don’t work, I’ve tried other configs from other threads - but none of them I regarding exactly this issue.
The problem seems to be to pick up the variable from the entity-button and pass it on to the shell-command.
