Passing variables from script to script
From a four way Z-wave wall switch (ZHC5010) I use two buttons to control my kitchen Sonos (entity_id: media_player.kkken).
One button to turn_on/toggle radio chanel and a second to turn_off radio.
In order to reuse my code base I have put my radio URLs in a separate script, and this is where my problems begin:
I seems like the script “play_radio” is not receiving the variables.
The error log shows the following:
2017-10-19 12:23:55 ERROR (MainThread) [homeassistant.core] Invalid service data for media_player.play_media: Entity ID media_player. is an invalid entity id for dictionary value @ data['entity_id']. Got 'media_player.'
How do I pass variables/values from script “next_preset_radio” to script “play_radio”?? Any Ideas to get my scripts working?
script:
  next_preset_radio:
    alias: 'Set Next Preset Radio'
    sequence:
      #NOTE TO SELF: Look into input_select.select_next
      - service: input_select.select_option
        data_template:
          entity_id: input_select.next_radio_dropdown
          option: >
            {% if is_state('input_select.next_radio_dropdown', 'P1') %}
              P6
            {% elif is_state('input_select.next_radio_dropdown', 'P6') %}
              24syv
            {% elif is_state('input_select.next_radio_dropdown', '24syv') %}
              P3
            {% elif is_state('input_select.next_radio_dropdown', 'P3') %}
              P1
            {% endif %}
      - service: media_player.volume_set
        #states.media_player[where].attributes.media_duration
        data_template:
          entity_id: "{{ 'media_player.' ~ where }}"
          volume_level: >
            {% if is_state('media_player.kkken', 'playing') %}
              {{ states.media_player[where].attributes.volume_level }}
            {% else %}
              {{ volume|default(0.2) }}
            {% endif %}
      - service: script.play_radio
        data_template:
            variables:
              where: "{{ where }}"
              station: "'{{ states('input_select.next_radio_dropdown') }}'"
Second script:
 play_radio:
        alias: 'Play preset radio on Sonos'
        sequence:
        - service: media_player.play_media
          data_template:
            media_content_id: >-
              {% if station == 'P1' %}
                x-rincon-mp3radio://live-icy.gss.dr.dk:80/A/A03H.mp3
              {% elif station == 'P3' %}
                x-rincon-mp3radio://live-icy.gss.dr.dk:80/A/A05H.mp3
              {% elif station == 'P6' %}
                x-rincon-mp3radio://live-icy.gss.dr.dk:80/A/A29H.mp3
              {% elif station == '24syv' %}
                x-rincon-mp3radio://http://streaming.radio24syv.dk/Web
              {% endif %}
            media_content_type: "MUSIC"
And my automations:
automation:
#Radio On
- alias: KITCHEN - NODE 3
  hide_entity: True
    platform: state
    entity_id: switch.switch_kitchen_main_switch_kitchen_n3
    service: script.turn_on
    entity_id: script.next_preset_radio
      variables:
        where: 'kkken'
        volume: 0.2
#Radio Off
- alias: KITCHEN - NODE 4
  hide_entity: True
    platform: state
    entity_id: switch.switch_kitchen_main_switch_kitchen_n4
    service: media_player.media_pause
Remove these two lines in your first script.
And in your Automation, I will use the following:
    service: script.next_preset_radio
        where: 'kkken'
        volume: 0.2
Instead
On another note, I like the way you used the square brackets below:
Never knew that worked. Thanks for the example
Regards
@Odianosen25 YOU ARE A CHAMP! :metal::brain::sunglasses:
I still need to fix the small bit of hard code I the script next_preset_radio:
But first CELEBRATION!
The code now looks like this:
Scripts
next_preset_radio:
    sequence:
      - service: input_select.select_next
        data_template:
          volume_level: >
            {% else %}
            {% endif %}
        data_template:
          station: "{{ states('input_select.next_radio_dropdown') }}"
  play_radio:
    sequence:
      data_template:
          {% endif %}
Automations
#Radio On
hide_entity: True
platform: state
where: ‘kkken’
volume: 0.2
#Radio Off
  hide_entity: True
    platform: state
You welcome and glad I could be of help
Do u mean you have a problem with the above line of code?
Regards
The idea is to make to code reusable on all media players, but in the code snippet above, I have hard coded the media_player named “kkken”.
This must be fixed, but for now, Im just happy that it all works!
Have you been into HASS for a long time? I my self got into it about a year ago, but only recently have I really begun complex automations - so a lot of learning and a lot of frustrations :wink:
/Tonkin
Looking at the code this dissent look all that hard!?!
If I in next_preset_radio change:
To:
{% if is_state( states.media_player[where] , 'playing') %}
Should work. I’ll try soon!
Hello @Tonkin,
Well I am into HA for less than a year to be honest, but I love programming as a person and did a bit of C++ a long time ago when in school.
As regards the below
I think you should try this if it doesn’t work
{% if 'states.media_player.' ~ where ~ '.state' == 'playing' %}
And please let me know how it goes, as I will like to know the result myself. I would have tried it, but not home now to access my system
Regards
Did you ever get this media player variable to work? I’m have something similar and cant seem to get to work.
If you mean based on what I wrote here
Which was wrong, this is the right way to do it instead
{% if  states('media_player.' ~ where) == 'playing' %}
Regards
That did it, thank you so much. What I ended up doing was to pass the entire entity_id as the variable and then reference is as
{% if is_state(where , 'playing' %}
But I like your way better so i’m switching.
hello Odianosen25
with your help the if statement works, however, i cannot seem to get the entity_id to work. Please help.
- service_template: >
    {% if states('media_player.' ~ where) == 'off' %}
      media_player.turn_on
    {% endif %}
  entity_id: 'media_player.' ~  where
