Passing variables to a script using button card
Hi all,
I’m struggling trying to pass a couple of variables from a button card to a script.
I read a lot of similar topics but I didn’t find a solution for myself.
Please find below my code:
Script:
change_view:
  alias: change_view
  sequence:
    - service: input_select.select_option
        entity_id: input_select.menu_item
        #option: "{{option}}" This option does not work
        option: weather
Button:
type: button
name: Test Automation (Input)
show_state: false
tap_action:
  action: call-service
  service: script.change_view
  service_data:
    entity_id: script.change_view
      option: weather
If I try to pass the “option” variable the script does not work.
I will appreciate any help.
Many thanks in advance to all.
Roberto
…7 months later
Does anyone know if this is possible?
Should this not be…
type: button
show_state: false
tap_action:
  service_data:
    option: weather
Then the script becomes…
change_view:
  alias: change_view
  sequence:
