Peblar: Change LED brightness
I want to be able to switch the LED brightness between Off and Automatic (as can be done via the Peblar web interface) from a HA automation, so that I can also turn off the LED when my automation is preventing charging.
In my case, this would be when my EV is not home.
My Peblar EVSE is connected via the core integration for Peblar: Peblar - Home Assistant
