'Pending' not showing on lovelace alarm-panel when setting arm_away
I am using the following yaml for my alarm-panel card. All of the commands execute correctly, I can arm_home, arm_away, and disarm successfully, however none of the commands are needing a pin code (and the key pad is not showing).
Additionally, when I do an arm_away, the 30 second countdown does not show in the card (‘Pending’ icon in top right), so it’s difficutly to tell if the command is actually executing - for example when I am not home and trying to arm the system, because I can’t physically hear the countdown and there is no indication on my card that it is counting down, I don’t know if anything is happening…
entity: alarm_control_panel.abode_alarm
states:
  - arm_home
  - arm_away
type: alarm-panel
Capture
This must be a problem with Abode integration, because I have both MQTT Alarm and Alarmdecoder and they show these things on the UI.
