Hi, I would like to ask what is better approach, I have switch based on esp home and I would like to perform some actions based on single click (toggle light), double click (toggle light color) and long press (toggle brightness). Currently I have implemented it in the esp home it self, so it triggeres script, this way it should be probably the fastest way how to do it but it has some disadvantages. I plan to do the same for all my switches at home but that would mean that each switch would have different esp home configuration. I could also create three entities which would turn on and of for single press, double press and long press and than create automations based on that. Any advice what would be the best aproach?
CURRENT CONFIG:
# Configuration
substitutions:
esphome:
esp8266:
board: esp8285
restore_from_flash: true
# Enable logging
logger:
#Turn off RX TX
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: !secret esp_home_api_password
ota:
password: !secret esp_home_ota_password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "${name}.o"
password: !secret esp_home_fallback_wifi_password
captive_portal:
output:
- platform: gpio
pin: GPIO4
- platform: gpio
pin: GPIO5
switch:
- platform: output
name: "${name} relé 1"
icon: mdi:toggle-switch-variant
restore_mode: RESTORE_DEFAULT_ON
output: relay1
- platform: output
name: "${name} relé 2"
output: relay2
binary_sensor:
# Wired switch 1
- platform: gpio
name: "${name} vypínač 1"
icon: mdi:light-switch
pin:
number: GPIO1
mode: INPUT_PULLUP
inverted: true
on_multi_click:
#Single click
- timing:
- ON for at most 0.5s
- OFF for at least 0.2s
then:
- homeassistant.service:
service: script.turn_on
entity_id: script.svetlo_v_pracovne_klik
# Double click
- timing:
- OFF for at most 0.2s
then:
entity_id: script.svetlo_v_pracovne_dvojklik
#Long click
- timing:
- ON for at least 1s
then:
entity_id: script.svetlo_v_pracovne_dlouhy_klik
#Reset
- timing:
- ON for at least 5s
then:
- switch.toggle: switch_relay1
# Wired switch 2
- platform: gpio
name: "${name} vypínač 2"
pin:
number: GPIO3
mode: INPUT_PULLUP
inverted: true
on_multi_click:
# Single click
- timing:
then:
entity_id: script.svetlo_v_loznici_klik
# Double click
- timing:
then:
entity_id: script.svetlo_v_loznici_dvojklik
# Long click
- timing:
then:
entity_id: script.svetlo_v_loznici_dlouhy_klik
# Reset click
- timing:
then:
- switch.toggle: switch_relay2
# Button on mini switch
- platform: gpio
name: "${name} tlačítko"
icon: mdi:gesture-tap-button
pin:
number: GPIO14
mode: INPUT_PULLUP
inverted: true
on_multi_click:
- timing:
- ON for at most 1s
then:
- platform: status
text_sensor:
- platform: wifi_info
ip_address:
name: "${name} IP adresa"
icon: mdi:ip-network
- platform: wifi_signal
update_interval: 10s
- platform: uptime
name: "${name} doba běhu"
time:
- platform: sntp
