The problem is a spontaneous shutdown with an arbitrary frequency and each shutdown lasts 21 minutes.
esphome:
friendly_name: Wemos Office
esp8266:
board: d1_mini
logger:
level: VERBOSE
logs:
switch: ERROR
api:
ota:
- platform: esphome
wifi:
networks:
- ssid: Pro4
password: Milk33kg
power_save_mode: NONE
ap:
ssid: ProE
password: Milk33kg
binary_sensor:
- platform: gpio
pin: GPIO16
#званок двор пин D0
filters:
- delayed_on: 50ms # Фильтр дребезга (задержка 50 мс)
- platform: gpio
pin: GPIO12
#геркон двери пин D6
filters:
on_press:
then:
- switch.turn_on: output_alarm
- delay: 0.1s
- switch.turn_off: output_alarm
- platform: gpio
pin:
number: GPIO14 # номер GPIO пина, к которому подключена кнопка
#звонок офис пин D5
mode: INPUT_PULLUP # Включаем внутренний подтягивающий резистор (обычно используется с кнопками, замыкающими на GND)
inverted: true # Инвертируем логику
filters:
on_press:
then:
- delay: 1s
- platform: gpio
pin:
number: GPIO01
inverted: False
name: "PIR Sensor Office"
device_class: motion
filters:
- delayed_on: 3s
switch:
- platform: gpio
pin: GPIO04
#выход(звонок) пин D2
- platform: gpio
pin: GPIO05
#выход(звонок) пин D1
optimistic: true
optimistic: true
- platform: gpio
pin: GPIO2 # D4 (или другой свободный пин)
inverted: True
I don 't know what to do anymore . only when working from a powerbank does it seem to work stably, when working from a usb charger (different), it turns off at random for almost always 21 minutes, it can turn off after 4 hours, or maybe after 26 hours. I tried different wires, the blocks were also different , I put ferrite rings on both the supply wire and the input wires, all the pins on the input and output are tightened to ± or cons in accordance with the operating mode of the nominal value of 2+ kOhms. Moving the access point has no effect , I also changed the vemos d1 itself to a board from another manufacturer (soldered slightly differently ) , the same effect , other vem controllers and others working in this room with the same wifi do not experience such problems with disconnection . At the same time , when hanging for this 21 minutes , if you measure the board , then the 5v before the stabilizer and after 3.3V are stable . The board starts automatically after 21 minutes ± 30 seconds. The logs are empty before this glitch.
Given such a stable shutdown for exactly 21 minutes, I think maybe this is some kind of process that can work like that , or something else … otherwise, there would have been a quick reconnect after the failure . Maybe I touched (used) a sensitive pin…
Рус:
уже не знаю что и делать . только при работе от повербанка вроде работает стабильно , при работе от usb зарядного (разных) с рандомной периодичностью отключается на почти всегда 21 минуту , может отключиться через 4 часа, а может через 26 ч . Провода пробовал разные , блоки так же разные , кольца ферритовые ставил и на питания провод и на провода входы , все пины по входу и выходу подтянуты к ± или минусы в соответствии с режимом работы номинала 2+ кОм . Перемещение точки доступа не влияет , так же менял сам вемос д1 на плату другого производителя (распаяна чуть иначе ) , тот же эффект , другие контролеры вемом и прочие работающие в этм помещении с этим же вифи не испытывают таких проблем , с отключением . При этом при зависании на эту 21 минуту , если промерить плату то 5в до стабилизатора и после 3,3в стабильны . Плата сама запускается через 21 минуту ± 30 сек . Логи пустые перед этим глюком .
Учитывая такую стабильную отключаемость именно на 21 минуту , я думаю может это какой то процесс может так работать , или еще что то … иначе после сбоя был бы быстрый реконнект . Может я какой то пин тронул(использовал) чувствительный …
