Permissions for ./root/homeassistant/config in Container
Hi everyone,
I have HA on a container in Raspberry Pi and I can’t get to my config.yaml file because I dont seem to have permission to get to ./root
I installed it as indicated in HA webpage
Any ideas?
Thank you and sorry for the probably stupid qustion
I assume you ran
docker run -d \
  --name homeassistant \
  --privileged \
  --restart=unless-stopped \
  -e TZ=MY_TIME_ZONE \
  -v /PATH_TO_YOUR_CONFIG:/config \
  --network=host \
  ghcr.io/home-assistant/home-assistant:stable
So what did you type instead of /PATH_TO_YOUR_CONFIG
it was some time ago so i’m not really sure but I know that my configuration file is at:
/root/homeassistant/config/configuration.yaml
and then I have also something at:
./var/lib/docker/overlay2/1e92ab088e8e70fb464e7d5fc5b4317fa75f764f04987cc79032bd7ab4b83b8d/merged/usr/src/homeassistant/.pre-commit-config.yaml
EDIT: But I can’t access either of them…working from the raspberry itself
what user are you using on the pi?
Barraco@raspeberrypi
Well you’ll need to use sudo, change to the root user or change the permissions to allow that user to read and write those files.
My prefered action would be changing the permissions but I m not sure if I know how to do that…?
You need to get familiar with chown and chmod.
Ok will try to find out. Thanks
sudo chown "barraco:barraco " /root/“barraco”/homeassistant/ -R
sudo chmod g+rwx “root/homeassistant” - R
Would it be something like this?
Something like that yes, but I think on refleection that HA may change things back when you edit a file in the gui, or it creates a new file.
I’m not sure I understand what you’ trying to say? If with this I can edit the configuration.yaml I’ll be happy :blush:
