Every time I restart Home Assistant, I get this error, but the logs don’t give me a clue of how to fix it. Any tips would be appreciated.
What do your logs say?
Thanks for looking.
Here are the error lines referencing ssdp, dlna and default_config.
There are a few other integration errors that I haven’t been getting into, but these are the ones that show up with every restart, and “repair” doesn’t say anything.
ssdp
Home Assistant Core
Unable to set up dependencies of dlna_dmr. Setup failed for dependencies: ssdp
12:28:17 PM – (ERROR) setup.py - message first occurred at 12:28:17 PM and shows up 5 times
Setup failed for dlna_dms: (DependencyError(...), 'Could not setup dependencies: ssdp')
12:28:02 PM – (ERROR) setup.py - message first occurred at 12:27:49 PM and shows up 3 times
Unable to set up dependencies of dlna_dms. Setup failed for dependencies: ssdp
12:28:02 PM – (ERROR) setup.py - message first occurred at 12:27:49 PM and shows up 2 times
Error handling when_setup callback for frontend
12:27:39 PM – (ERROR) helpers/network.py - message first occurred at 12:27:38 PM and shows up 2 times
dlna
Home Assistant Core
default_config
Home Assistant Core
I did a grep of my config *.yaml
and “smarthing” shows nowhere, so I don’t know where that error is coming from.
This is the only related issue I could find:
How have you set up your http:
integration (show the config).
Thanks, yes. This is from my configuration.yaml:
http:
ssl_certificate: /ssl/fullchain.pem
ssl_key: /ssl/privkey.pem
ip_ban_enabled: true
login_attempts_threshold: 5
Actually it’s in the basic information section. You need to set:
homeassistant:
external_url:
internal_url:
Thanks- that fixed the ssdp and dnla errors. For some reason I thought that the homeassistant: component was depreciated?
Not depreciated, but you can set some of it up in the UI now (location, name, etc…).
