I am trying to make it that the persistent notification only shows on home WiFi, I want this because after my own testing it shows that having the persistent notification makes my automation notifications send faster.
It works and shows it when I have it set to “always” but why won’t it show when I set it to “on home WiFi only”?
I think you’re confusing notification with connection. That second option doesn’t control whether you’ll get a notification (on which network), but rather how it will be delivered (keeping a direct connection on your local network and thus will be faster).
Yea the problem is it’s not showing the persistent notification, it shows it when set to always but I don’t see it anymore when set to this.
Or will it come back when a notification is sent then go away again? When it was set to always it was always there and made notifications faster which is why I want it only show on home wifi.
For future reference, the purpose of marking a post with the Solution tag is to identify it as the one containing information to solve the originally stated problem. It’s to help others with a similar problem, quickly find an answer.
In this particular case, you marked your own post with the Solution tag but it contains no information explaining how to solve the problem.
