I’m truly at a loss for how to fix this.
I have an automation that, when a person is recognized at the front door, it creates a snapshot, saves it in a local folder (/local/snapshots/front_door_camera-snapshot.jjpg) and then sends a mobile phone notification as well as create a persistent notification.
The thumbnail that’s attached to my iPhone notification is so small it is essentially absolutely useless so when away from home, I simply use the notification as actionable to show me the live stream of my front door.
All of that works as intended.
The problem is with the persistent notification that “hangs-on” to whatever the last snapshot was and keep using that despite the file in the folder actually changing (being replaced after each snapshot). The only way that this automation works and inserts the correct image in the persistent notification is if I clear my browser cache. So that makes that absolutely worthless.
II suspect there’s something I screwed up somewhere but my google-fu is failing me severely. I’m hoping someone can point to where I’ve gone wrong. Here is my full automation…
alias: Mobile Notification When Person Detected At Front Door Between 8AM and 10PM
description: ""
triggers:
- type: turned_on
device_id: b951543b2ece3e9fa4116b22ac8a7f52
entity_id: de562265a2614685749cc9785e128e78
domain: binary_sensor
trigger: device
conditions:
- condition: time
after: "08:00:00"
before: "22:00:00"
actions:
- action: camera.snapshot
metadata: {}
filename: /config/www/snapshots/front_door_snapshot-doorbell.jpg
entity_id: camera.front_door_high_resolution_channel
- action: notify.mobile_app_myiphone
metadata: {}
message: There's someone at the front door
title: Person Detected!
image: https://[external_domain_redacted]/local/snapshots/front_door_snapshot-doorbell.jpg
actions:
- action: URI
title: Open Home Assistant
URI: [external_domain_redacted]/dashboard-mobile/0
- action: notify.persistent_notification
metadata: {}
title: Person detected!
message: >-
Someone is at the front door on {{ now().strftime("%Y-%m-%d at
%H:%M:%S") }}
mode: single
Everything works except the persistent notification
Help?!? I can’t figure out why only old snapshots are attached.
