I have a home with 4 Carrier branded (Midea Manufactured) Mini-split AC systems, and all are enabled with the WiFi module. I have been successfully using the Carrier “Air Conditioner” mobile app to run the units on a daily schedule mainly to control indoor humidity when we are away.
For each of the 4 units I established a schedule to run on AC mode at 3pm for 90 minutes and the same at 3am. I believe when I first set this up (Feb 2024), the app required separate schedule entries for the ON and OFF events, and at some point in the last 12 months or so there is a newer version of the app that allows an ON and OFF Time for one entry and I deleted and re-established the schedules using this new feature.
All good, but the problem is that one of my 4 units is still following the OLD schedule, even when I have all the current schedules disabled. It is as if my App is un-aware of this old schedule, yet on the server side of things that schedule still exists and is being executed daily. I have not been successful in resetting things to the point where this old schedule stops executing.
What I have tried, all to no avail
- deleted all schedule entries for that unit
- removed and re-installed the mobile app
- removed the device from the mobile app, and also the physical WiFi module from the indoor unit, then proceeded to configure it again as if a new device and re-establish the schedule
- I have also tried the Carrier CliMate app, which uses the same login credentials as the Air Conditioner app, and I see my exact same setup including schedules, scenes etc. So, I believe this may be an older version, or maybe IOS only version?
- I have looked online to see if there is a Carrier web portal where I could check. As far as I can tell, there is a portal for Carrier smart home app, but not for the Air Conditioner app
Has anyone experienced this? Any thoughts on getting rid of the old schedule? I suppose I could try to initiate a support request with Carrier and see where that goes.
Thank you.
