Hello -
Hoping someone can help me. I have an annoying log entry that doesn’t seem to be causing any issues but I can’t track it down. It’s referencing a device that’s been off the system for a number of weeks. I recently finally moved off of Vera and removed the integration. (It left a few devices behind that I can’t remove but that’s a different problem and this device doesn’t show up in Entities).
I have no templates that I know of. No dashboards calling this. Any idea where I can look?
Logger: homeassistant.helpers.event
Source: helpers/template.py:645
First occurred: 10:07:49 PM (3 occurrences)
Last logged: 10:52:25 PM
Error while processing template: Template<template=({{ states('sensor.office_temperature_398')| round(1)}}°F) renders=2>
Error while processing template: Template<template=({{ states('sensor.office_temperature_398')| round(1)}}°F) renders=6>
Error while processing template: Template<template=({{ states('sensor.office_temperature_398')| round(1)}}°F) renders=10>
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1940, in forgiving_round
value = round(float(value), precision)
ValueError: could not convert string to float: 'unknown'
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 643, in async_render
render_result = _render_with_context(self.template, compiled, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 2745, in _render_with_context
return template.render(**kwargs)
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 1295, in render
self.environment.handle_exception()
File "/usr/local/lib/python3.13/site-packages/jinja2/environment.py", line 942, in handle_exception
raise rewrite_traceback_stack(source=source)
File "<template>", line 1, in top-level template code
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1945, in forgiving_round
raise_no_default("round", value)
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 1921, in raise_no_default
raise ValueError(
...<2 lines>...
ValueError: Template error: round got invalid input 'unknown' when rendering template '{{ states('sensor.office_temperature_398')| round(1)}}°F' but no default was specified
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 760, in async_render_to_info
render_info._result = self.async_render( # noqa: SLF001
variables, strict=strict, log_fn=log_fn, **kwargs
File "/usr/src/homeassistant/homeassistant/helpers/template.py", line 645, in async_render
raise TemplateError(err) from err
homeassistant.exceptions.TemplateError: ValueError: Template error: round got invalid input 'unknown' when rendering template '{{ states('sensor.office_temperature_398')| round(1)}}°F' but no default was specified
