Is there a way to intergrate PHIDGETS (https://phidgets.com) in to Home Assistant?
Phidgets have (wireless) hubs and many types of interfaces, like Exact temperature readers, proximity readers, Digital inputs / outputs and Relay outputs.
I use a Panasonic heat pump which I would like to Automate using the much more precise readings of Phidgets (temperature) and for example open door / window detection.
I use several Phidgets attached to Raspberry Pis. A single Raspberry Pi runs the Phidgets network server and listens for changes on digital and analog inputs. That central Raspberry Pi pushes the input states into MQTT and Home Assistant MQTT sensors bring that data into Home Assistant. I do not use any Digital outputs, only digital inputs and analog inputs. I keep hoping that someone with real python talent will integrate Phidgets into HA. The Phidgets system is very useful.
