Hi there,
I’ve got a Philio pan06 switch with id=“0013” I copied the vendor specific zwave config file from the ‘old’ pan06 with the id=“0004” which makes the switch to be alive. But if triggered by the external switches it sends wrong updates.
eg. If activating external switch 2 the switch 1 is activated. If I then manually refresh the zwave node the values are correct again. But then if I switch of the external switch 2 no update at all is given to home assistant.
Has anyone had similar problems and was able to solve them?
Best regards
Robert
