action: camera.snapshot
filename: /config/www/babycam_{{ now().strftime("%Y%m%d-%H%M%S") }}.jpg
entity_id: camera.babycam_camera
When I try this, I'm getting the following error:
Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:532
First occurred: 21:52:08 (1 occurrence)
Last logged: 21:52:08
websocket_api script: Error executing script. Unexpected error for call_service at pos 1:
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 532, in _async_step
await getattr(self, handler)()
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1027, in _async_step_call_service
response_data = await self._async_run_long_action(
...<9 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 642, in _async_run_long_action
return await long_task
File "/usr/src/homeassistant/homeassistant/core.py", line 2827, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2870, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 951, in entity_service_call
response_data = await _async_handle_entity_calls(
...<5 lines>...
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 830, in _async_handle_entity_calls
single_result = await entity.async_request_call(_with_context(entity, coro))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1696, in async_request_call
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 825, in _with_context
return await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 909, in _handle_single_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 1012, in async_handle_snapshot_service
else await camera.async_camera_image()
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 575, in async_camera_image
return await self.hass.async_add_executor_job(
partial(self.camera_image, width=width, height=height)
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 86, in run
result = ctx.run(self.task)
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 73, in run
return fn(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/camera/__init__.py", line 569, in camera_image
raise NotImplementedError
NotImplementedError
and
First occurred: 21:46:01 (1 occurrence)
Last logged: 21:46:01
...<9 lines>...
...<5 lines>...
return await coro
return await coro
result = await task
NotImplementedError
Even though the video stream is running.
