Philips friend of hue wallswitch (Feller and others)
That’s how I got my Philips friend of hue wallswitch (Feller ediziodue) running. The following functions work perfectly:
  • on/off on the same button
  • on/off same device on different wallswitch
  • use 12 different trigger on 4 buttons
    • 4 release (short push)
    • 4 press (long push)
    • both upper button together (release + press)
    • both lower button together (release + press)
  • the press and release trigger will not double triggering, by using just the press
My equipment: Hassio on raspberry pi 3b, v0.107, Philips Bridge 2.0, friend of hue wallswitch
First you have to connect your friend of hue wall switch with the philips hue app.
After you have to install this custom component: https://github.com/home-assistant/core/pull/9796
Just copy the files on your home assistant and reboot your system (no yaml configuration)
@ [robmarkcole] you made a great job - thanks a lot
My example, don’t use all the buttons (to keep the script “simple”) and includes the following scenario:
  • button 1 on switch 1
    • release to turn on / off light 1
    • press to start / stops play radio station on a sonos speaker
  • button 2 on switch 1
    • release to turn on / off light 2
setup in configruation.yaml:
hue:
  bridges:
    - host: 192.168.xxx.xxx # your IP from Philips HUE bridge
  - platform: hue
    ip_address: 192.168.xxx.xxx # your IP from Philips HUE bridge
    token: 53fUFmxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx # your token from Philips HUE bridge
  - platform: huesensor
  - platform: template # a sensor with buttom information, using in the automation
    sensors:
      switch_1_status:
        friendly_name: 'switch_1_status'
        value_template: '{{states.sensor.<switchname_in_the_hue_app>.state}}'
  - platform: template # a sensor with a timestamp, using in the automation
    sensors:
      switch_1_update2:
        friendly_name: 'switch_1_update2'
        value_template: '{{states.sensor.<switchname_in_the_hue_app>.last_updated}}'
input_boolean: # use for: the press and release trigger will not double triggering, by using just the press (this state turn on for a few second, after use the press trigger)
  switch_1_lock:
    name: 'switch 1 lock'
    initial: off
    icon: mdi:microsoft
automation:
  - alias: 'lamp_1_turn_on'
      platform: state
      entity_id: sensor.switch_1_update2
    condition:
      - condition: state
        entity_id: sensor.switch_1_status
        state: "right_upper_release"
      - condition: state
        entity_id: light.lamp_1
        state: 'off'
      - condition: state # use for: the press and release trigger will not double triggering, by using just the press (this condition check if use a press for a few second ago)
        entity_id: input_boolean.switch_1_lock
        state: 'off'
      - service: light.turn_on # I don't use toggle because I would like to reset the brightness and color.
          brightness: 255
          rgb_color: [255, 255, 255]
  - alias: 'lamp_1_turn_off'
      platform: state
    condition:
      - condition: state
      - condition: state
        state: 'on'
      - condition: state
        state: 'off'
      - service: light.turn_off
  - alias: 'lamp_2_turn_on'
      platform: state
    condition:
      - condition: state
        state: "right_lower_release"
      - condition: state
        entity_id: light.lamp_2
        state: 'off'
      - condition: state
        state: 'off'
          brightness: 255
  - alias: 'lamp_2_turn_off'
      platform: state
    condition:
      - condition: state
      - condition: state
        state: 'on'
      - condition: state
        state: 'off'
 - alias: 'play_radiostation1'
      platform: state
    condition:
      - condition: state
        state: "right_upper_press"
      - condition: state
        entity_id: media_player.room1
        state: 'paused'
      - service: input_boolean.turn_on # use for: deactivates the release function for a few seconds
      - service: media_player.volume_set
        data_template:
          volume_level: 0.08
      - service: media_player.select_source
        data_template:
          source: 'Radiostation1'
      - service: media_player.play_media
          media_content_type: music
      - delay: 00:00:03
      - service: input_boolean.turn_off # use for: activates the release function after a few seconds
 - alias: 'stop_radiostation1'
      platform: state
    condition:
      - condition: state
      - condition: state
        state: 'play'
      - service: media_player.media_pause
      - delay: 00:00:03
If you have a second wall switch, you can also operate the same devices. Copy both “platform: template” also the automations and change the sensor names.
I know there are solutions with fewer lines (let me know, if you have some inputs), but this solution works quickly and with 99.8% reliability.
Hi Yves_IF
Kannst du mit diesem Setup eine Hue Lampe dimmen oder kannst du einfach 12 verschiedene Szenen einstellen? Der long push wird ja nur einmal aktiviert oder?
The long push is triggered only once by holding. So you cannot dim by holding. But you can e.g. + 20% brightness per (long or short) push.
(you are lucky - my native language are german :laughing:)
Hi, I have juste a little question. How does the feller wallswitch now to use the configuration from HA rather then what was configurated in the Hue app? I have a lot of Feller wallswitches configured in the hue app and I juste want some specific configuration on one button.
In this configuration, HA only listens to the button-events. That means, whether you have configured a button in the hue app or not, HA carries out the above configuration. So your project is possible. Good luck :wink:
Hey!
Super, herzlichen Dank!
I’m just about to purchase some wiser bei feller switches for some trials (prep for new house build), specifically the 1Kanal Storenschalter. Has anyone here had any experience with this switch? It looks like the device is a WiFi based switch.
I’m assuming I’ll need to buy the WiF version for every switch and I’ll also need something to connect some hardware between the switch and Home Assistant so it can be visible in HA.
Is my understanding correct here? Any other wiser feller switches (specifically) used by others on here?
I have no experience with this button. I use the Hue Feller switch and trigger the necessary command for the sun blind motor (RF signal) via HA.
Take a look at the Shellys with which you can control the motors and you can use normal (not smart) wall switches.
I try to integrate this cool Blueprint but to be honest i am struggling with the guideline. I don’t understand the second step:
Which files and to which target folder?
Can somebody please give a hint or explain how to do it?!
Thank you in advance!
Hi
Thank you for the write-up @Yves_IF.
Question: Do I only need the Hue app on my phone to set everything up, or do I also need a Philips Hue bridge for that?
Reason I‘m asking is that I switched to a Sonoff Zigbee stick a while ago to unify everything under one device and no longer have/use a Philips Hue bridge
To be honest, this blueprint is quite outdated. Meanwhile, there are better ways for integaration. I am currently using a Zigbee USB dongle (Conbee2), which is plugged into the Home Assistant server. This is how I control all Ikea, Hue and Aqara devices. I no longer integrated the Hue Bridge.
@KerTana You need the bridge or a Zigbee USB dongle (just the app is not enough). Although nowadays I would decide on the Sonoff dongle and Zigbee2MQTT.
