Philips Hue Dimmer and Bulb kit
Hi, i’ve taking my first steps in the home automation world and after a few tests i think i have found my starting point: a Rpi 3 with home assistant and a conbee ii stick.
Everything is working fine (even though i only have a temperature sensor and a dimmer switch at the moment).
I had no trouble adding the tem sensor via deConz, and the dimmer was also relatively easy but i have some questions regarding the latter.
After configuring the dimmer in deConz, I no longe operates my bulb. The led blinks green but there’s no change in the bulb (intensity nor status).
This is the kit I have
The box states that it is both bluetooth and zigbee but from the tests i’ve made I think the dimmer is zigbee and the bulb is bluetooth, right? If so, is there any way to control the bulb from home assistant (even if it has to go through the dimmer)?
What happened during the configuration that is preventing the dimmer to operate the buld (and they seem to be correctly paired)?
Thank you for your patience. I’m a total newbie in the subject and have been looking for these answers in the foruns but with no success. If there is no way yo integrate these few devices in my eco system i might return them.
I guess the sooner I had posted my questions, the sooner I had found the answer
Everything is working as I expected now. Thanks anyway.
