Philips Hue Dimmer Switch v2 (Zigbee2MQTT)
Has anyone managed to get the hold actions working correctly? I’m using @pantherale0’s Blueprint and have tried a few making a few tweaks for down_hold etc. but can’t seem to get working without breaking other functions. I am currently using Switch Manager - New refined switch integration to manage your switches instead which does handle hold presses OK if anyone else is struggling with this.
Here is my working blueprint incl. the holding function.
File “hue_929002398602_mqtt.yaml”:
blueprint:
  name: Philips Hue Dimmer switch v2 (Zigbee2MQTT)
  description:
    "Tested with Philips Hue Smart Wireless Dimmer Switch V2 (929002398602).
    \n\n To have different actions on short press and on hold (long press), use 'button
    release' (`*_press_release`) and 'button hold once' (`*_hold_once`) commands,
    as 'press' (`*_press`) will always trigger before 'button hold' (`*_hold`). \n\n
    When you hold a button, 'button hold' (`*_hold`) command is repeated roughly once
    per second. This may not work as desired with actions like toggling light/switch.
    If you want an action to run only once when the button hold action is registered,
    use 'button hold once' (`*_hold_once`). It's better than using 'button hold release'
    as the result can be observed before releasing the button after holding. \n\n
    As 'button hold' action is repeated by the device while you keep holding the button,
    it's a good way to run actions which increment / decrement some value (such as
    light dimming). To make it react as soon as the button is pressed, copy the same
    action to 'button press' (press action occurs immediately, while hold action occurs
    after a delay). \n\n Make sure to manually create a separate Text Helper per dimmer
    device and define its entity in the automation. It's used to store the last controller
    event to filter possible empty events and handle 'button hold once' actions. "
  domain: automation
  input:
    mqtt_topic:
      description: Topic of the Philips Hue Motion
      default: zigbee2mqtt/<device name>
    helper_last_controller_event:
      name: (Required) Helper - Last Controller Event
      description:
        Input Text used to store the last event fired by the controller.
        You will need to manually create a text input Helper entity for this.
      default: ""
      selector:
        entity:
          domain:
            - input_text
          multiple: false
    on_press:
      name: ON button press
      description: Action to run
      default: []
      selector:
        action: {}
    on_press_release:
      name: ON button release
      default: []
      selector:
        action: {}
    on_hold:
      name: ON button hold
      description: Action to run (repeat while holding)
      default: []
      selector:
        action: {}
    on_hold_once:
      name: ON button hold once
      description: Action to run only once (no repeat)
      default: []
      selector:
        action: {}
    on_hold_release:
      name: ON button hold release
      default: []
      selector:
        action: {}
    up_press:
      name: UP button press
      default: []
      selector:
        action: {}
    up_press_release:
      name: UP button release
      default: []
      selector:
        action: {}
    up_hold:
      name: UP button hold
      default: []
      selector:
        action: {}
    up_hold_once:
      name: UP button hold once
      default: []
      selector:
        action: {}
    up_hold_release:
      name: UP button hold release
      default: []
      selector:
        action: {}
    down_press:
      name: DOWN button press
      default: []
      selector:
        action: {}
    down_press_release:
      name: DOWN button release
      default: []
      selector:
        action: {}
    down_hold:
      name: DOWN button hold
      default: []
      selector:
        action: {}
    down_hold_once:
      name: DOWN button hold once
      default: []
      selector:
        action: {}
    down_hold_release:
      name: DOWN button hold release
      default: []
      selector:
        action: {}
    off_press:
      name: OFF/HUE button press
      default: []
      selector:
        action: {}
    off_press_release:
      name: OFF/HUE button release
      default: []
      selector:
        action: {}
    off_hold:
      name: OFF/HUE button hold
      default: []
      selector:
        action: {}
    off_hold_once:
      name: OFF/HUE button hold once
      default: []
      selector:
        action: {}
    off_hold_release:
      name: OFF/HUE button hold release
      default: []
      selector:
        action: {}
  source_url: https://gist.github.com/CrazyCoder/28d660d9e2e8464458e591ad79b3698e
mode: restart
max_exceeded: silent
  - platform: mqtt
    topic: !input mqtt_topic
condition:
  - condition: template
    value_template: "{{ 'action' in trigger.payload_json and trigger.payload_json.action != '' }}"
  - variables:
      helper_last_controller_event: !input helper_last_controller_event
      command: "{{ trigger.payload_json.action }}"
      prev_command: "{{ states(helper_last_controller_event) }}"
  - service: input_text.set_value
      entity_id: !input helper_last_controller_event
      value: "{{ command }}"
  - choose:
      - conditions:
          - '{{ command == "on_press" }}'
        sequence: !input on_press
      - conditions:
          - '{{ command == "on_press_release" }}'
        sequence: !input on_press_release
      - conditions:
          - '{{ command == "on_hold" }}'
        sequence: !input on_hold
      - conditions:
          - '{{ command == "on_hold_release" }}'
        sequence: !input on_hold_release
      - conditions:
          - '{{ command == "up_press" }}'
        sequence: !input up_press
      - conditions:
          - '{{ command == "up_press_release" }}'
        sequence: !input up_press_release
      - conditions:
          - '{{ command == "up_hold" }}'
        sequence: !input up_hold
      - conditions:
          - '{{ command == "up_hold_release" }}'
        sequence: !input up_hold_release
      - conditions:
          - '{{ command == "down_press" }}'
        sequence: !input down_press
      - conditions:
          - '{{ command == "down_press_release" }}'
        sequence: !input down_press_release
      - conditions:
          - '{{ command == "down_hold" }}'
        sequence: !input down_hold
      - conditions:
          - '{{ command == "down_hold_release" }}'
        sequence: !input down_hold_release
      - conditions:
          - '{{ command == "off_press" }}'
        sequence: !input off_press
      - conditions:
          - '{{ command == "off_press_release" }}'
        sequence: !input off_press_release
      - conditions:
          - '{{ command == "off_hold" }}'
        sequence: !input off_hold
      - conditions:
          - '{{ command == "off_hold_release" }}'
        sequence: !input off_hold_release
  - choose:
      - conditions:
          - '{{ command == "on_hold" and prev_command == "on_press" }}'
        sequence: !input on_hold_once
      - conditions:
          - '{{ command == "up_hold" and prev_command == "up_press" }}'
        sequence: !input up_hold_once
      - conditions:
          - '{{ command == "down_hold" and prev_command == "down_press" }}'
        sequence: !input down_hold_once
      - conditions:
          - '{{ command == "off_hold" and prev_command == "off_press" }}'
        sequence: !input off_hold_once
thank you for your great blueprint.
i am using on press and hold(once) for different features, and if i intend to use hold(once) on press is triggered too. is this intended? if so should i use on release?
Yes, it’s in the description of the blueprint:
To have different actions on short press and on hold (long press), use ‘button release’ (*_press_release ) and ‘button hold once’ (*_hold_once )
Here is how I solved my issue! Its working great! For some reason, changing the rate in the delay node isn’t working, but I can change the tick up in the payload. Lower than 80 completely bricks wled integration, so this is the lowest I was able to make it.
[{"id":"74bf69f207c10ffa","type":"switch","z":"102803786c01f817","name":"Which payload?","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"up_press","vt":"str"},{"t":"eq","v":"up_hold","vt":"str"},{"t":"eq","v":"up_hold_release","vt":"str"},{"t":"eq","v":"down_press","vt":"str"},{"t":"eq","v":"down_hold","vt":"str"},{"t":"eq","v":"down_hold_release","vt":"str"}],"checkall":"true","repair":false,"outputs":6,"x":660,"y":1600,"wires":[["1142de7afe27d649"],["228f24fef5e96892"],["f131fdf6645a8124"],["1ad8200a531d1ad9"],["7190a623fb36a9ae"],["28bd40501809b971"]]},{"id":"7fcaeb49f9c60b4b","type":"change","z":"102803786c01f817","name":"msg.payload = action","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":1600,"wires":[["74bf69f207c10ffa","a6751a65462edf11"]]},{"id":"1142de7afe27d649","type":"api-call-service","z":"102803786c01f817","name":"↑ single step +10%","server":"e3d85e14.7c261","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.led_canto"],"labelId":[],"data":"{\"brightness_step_pct\":5}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"blockInputOverrides":false,"domain":"light","service":"turn_on","output_location":"","output_location_type":"none","x":930,"y":1540,"wires":[[]]},{"id":"228f24fef5e96892","type":"function","z":"102803786c01f817","name":"Generate first tick (up)","func":"return { payload: \"tick_up\", rate: 80 };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":930,"y":1600,"wires":[["750330ab0034861b"]]},{"id":"f131fdf6645a8124","type":"change","z":"102803786c01f817","name":"Stop ↑ loop","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":960,"y":1640,"wires":[["750330ab0034861b"]]},{"id":"1ad8200a531d1ad9","type":"api-call-service","z":"102803786c01f817","name":"↓ single step -10%","server":"e3d85e14.7c261","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.led_canto"],"labelId":[],"data":"{\"brightness_step_pct\":-10}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"blockInputOverrides":false,"domain":"light","service":"turn_on","output_location":"","output_location_type":"none","x":930,"y":1760,"wires":[[]]},{"id":"7190a623fb36a9ae","type":"function","z":"102803786c01f817","name":"Generate first tick (down)","func":"return { payload: \"tick_down\", rate: 80 };","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":940,"y":1820,"wires":[["f07d7f962f3931da"]]},{"id":"28bd40501809b971","type":"change","z":"102803786c01f817","name":"Stop ↓ loop","rules":[{"t":"set","p":"reset","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":960,"y":1860,"wires":[["f07d7f962f3931da"]]},{"id":"64a1951834d0371a","type":"mqtt in","z":"102803786c01f817","name":"MQTT – Interruptor Hue (action)","topic":"zigbee2mqtt/Interruptor Hue/action","qos":"0","datatype":"auto-detect","broker":"fbac6eb7e98975f5","nl":false,"rap":true,"rh":0,"inputs":0,"x":160,"y":1600,"wires":[["7fcaeb49f9c60b4b"]]},{"id":"a6751a65462edf11","type":"debug","z":"102803786c01f817","name":"debug 5","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":560,"y":1760,"wires":[]},{"id":"750330ab0034861b","type":"delay","z":"102803786c01f817","name":"Rate-limit ↑ at 50 ms","pauseType":"rate","timeout":"0","timeoutUnits":"ms","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"0","randomLast":"0","randomUnits":"ms","drop":false,"allowrate":true,"outputs":1,"x":1250,"y":1620,"wires":[["750330ab0034861b","314d37175a5554ab","437c43d1251376d8"]]},{"id":"f07d7f962f3931da","type":"delay","z":"102803786c01f817","name":"Rate-limit ↓ at 50 ms","pauseType":"rate","timeout":"0","timeoutUnits":"ms","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"0","randomLast":"0","randomUnits":"ms","drop":false,"allowrate":true,"outputs":1,"x":1250,"y":1840,"wires":[["5db70163f2eaaf33","f07d7f962f3931da"]]},{"id":"314d37175a5554ab","type":"debug","z":"102803786c01f817","name":"debug 4","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1380,"y":1560,"wires":[]},{"id":"437c43d1251376d8","type":"api-call-service","z":"102803786c01f817","name":"↑ step +4%","server":"e3d85e14.7c261","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.led_canto"],"labelId":[],"data":"{\"brightness_step_pct\":4}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"blockInputOverrides":false,"domain":"light","service":"turn_on","output_location":"","output_location_type":"none","x":1530,"y":1620,"wires":[[]]},{"id":"5db70163f2eaaf33","type":"api-call-service","z":"102803786c01f817","name":"↓ step -4%","server":"e3d85e14.7c261","version":7,"debugenabled":false,"action":"light.turn_on","floorId":[],"areaId":[],"deviceId":[],"entityId":["light.led_canto"],"labelId":[],"data":"{\"brightness_step_pct\":-4}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"blockInputOverrides":false,"domain":"light","service":"turn_on","output_location":"","output_location_type":"none","x":1530,"y":1840,"wires":[[]]},{"id":"e3d85e14.7c261","type":"server","name":"Home Assistant","addon":true},{"id":"fbac6eb7e98975f5","type":"mqtt-broker","name":"","broker":"192.168.0.2","port":"1883","clientid":"HAMQTT","autoConnect":true,"usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"autoUnsubscribe":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"userProps":"","sessionExpiry":""}]
Has anyone got a dummies guide?
Really struggling with this, to be honest
Go to Home Assistant > zigbee2mqtt’s web ui > Settings > Home Assistant integration
If you have “Home Assistant legacy action sensors” enabled, then you can use this blueprint by JetSerge:
If you have “Home Assistant experimental event entities” enabled, then you need to use 11harveyj’s fork of JetSerge’s blueprint:
If you use my blueprint (manually create the file file editor or SSH) from here: Philips Hue Dimmer Switch v2 (Zigbee2MQTT) - #83 by pOpY
You dont need the legacy setting.
This is yet another way, although not blueprint per se, but straight automation.
Background, I’m using the hue dimmer switch v2 with z2m and without any legacy flags in z2m, and a zigbee blub that does RGBW. And I build the whole thing using automation UI - those triggers are device triggers so your device id for the hue dimmer switch will be different for sure.
Again, not blueprint per se, but figured I could at least share.
alias: Bulb Kitchen Sink operations per hue dimmer switch
description: ""
triggers:
  - domain: mqtt
    device_id: ababababababababababab
    type: action
    subtype: on_press_release
    trigger: device
  - domain: mqtt
    type: action
    subtype: up_press_release
    trigger: device
  - domain: mqtt
    type: action
    subtype: down_press_release
    trigger: device
  - domain: mqtt
    type: action
    subtype: off_press_release
    trigger: device
  - domain: mqtt
    type: action
    subtype: off_hold_release
    trigger: device
  - domain: mqtt
    type: action
    subtype: off_hold
    trigger: device
conditions: []
actions:
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - data:
              transition: 1
              brightness_pct: 75
              entity_id:
                - light.bulb_kitchen_sink_rgbw
            action: light.toggle
      - conditions:
          - condition: state
            entity_id: light.bulb_kitchen_sink_rgbw
            state: "off"
        sequence:
          - data:
              transition: 0
              brightness_pct: 1
              entity_id:
            action: light.turn_on
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - data:
              transition: 1
              brightness_step_pct: 24
              entity_id:
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - data:
              transition: 1
              brightness_step_pct: -24
              entity_id:
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - data:
              hs_color:
                  {{ (state_attr("light.bulb_kitchen_sink_rgbw", "hs_color")[0]
                  + 60) % 360 }}
                - 100
              transition: 1
      - conditions:
            id:
              - hue_on_hold
          - condition: state
            state: "off"
        sequence:
          - data:
              transition: 2
              brightness_pct: 100
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - data:
              transition: 2
              entity_id:
            action: light.turn_off
      - conditions:
            id:
              - hue_off_hold
          - condition: state
            state: "on"
        sequence:
          - data:
              color_temp_kelvin: 3000
              transition: 1
mode: restart
Hello everyone,
I’m struggling a bit with the new event system of HA and the dimmer switch v2.
I did enable the experimental feature on z2m but I can’t find the “event” entity of the switch. Do I need to do something special to make sure it’s “created/seen” by HA?
Anything I can do to check that it actually does exists on the z2m side of things?
im stuck with the same problem.
I have a blueprint I’ve been testing (Zigbee2MQTT), the holding of the brighten/dim buttons I don’t believe is working properly atm, but short presses are good. You need to create 2 input booleans in your config.yaml to attempt to get the hold dimming working (feel free to change the names, just make sure to restart HA after editing the config.yaml or they won’t show up when setting up the blueprint):
input_boolean:
  media_room_brighten:
    name: Brighten Media Room
    icon: mdi:sun
  media_room_dim:
    name: Dim Media Room
    icon: mdi:moon
and the blueprint code is:
blueprint:
  name: Hue Switch – Switch Multi-Flow (Device + Light + Booleans)
  description: >
    Combines toggle, hold-to-brighten/dim (with repeat), and instant bright/dim.
    Select the MQTT device, the target light, and two input booleans.
  domain: automation
  input:
    remote_device:
      name: MQTT Button/Remote Device
      description: The MQTT device that emits action events (on_press, up/down hold, etc.)
      selector:
        device:
          integration: mqtt
    light_entity:
      selector:
        entity:
          domain: light
    brighten_boolean:
      selector:
        entity:
          domain: input_boolean
    dim_boolean:
      selector:
        entity:
    step_size:
      description: Amount to change brightness each tick (positive for brighten, negative for dim path).
      default: 10
      selector:
        number:
          min: 1
          max: 50
          step: 1
          mode: slider
    tick_ms:
      name: Repeat Interval (ms)
      description: How often to apply the step while holding.
      default: 500
      selector:
        number:
          min: 100
          max: 2000
          step: 50
          unit_of_measurement: ms
mode: parallel
max: 10
  # Button actions from the MQTT device
  - id: toggle
    platform: device
    domain: mqtt
    device_id: !input remote_device
    type: action
    subtype: on_press
  - id: brighten_hold
    platform: device
    domain: mqtt
    type: action
    subtype: up_hold
  - id: brighten_release
    platform: device
    domain: mqtt
    type: action
    subtype: up_hold_release
  - id: dim_hold
    platform: device
    domain: mqtt
    type: action
    subtype: down_hold
  - id: dim_release
    platform: device
    domain: mqtt
    type: action
    subtype: down_hold_release
  - id: instant_bright
    platform: device
    domain: mqtt
    type: action
  - id: instant_dim
    platform: device
    domain: mqtt
    type: action
  # State triggers to start the repeat loops
  - id: brighten_loop
    platform: state
    entity_id: !input brighten_boolean
    to: 'on'
  - id: dim_loop
    platform: state
    entity_id: !input dim_boolean
    to: 'on'
  - choose:
      # Toggle light
      - conditions: "{{ trigger.id == 'toggle' }}"
        sequence:
          - service: light.toggle
              entity_id: !input light_entity
              transition: 1
      # Hold to brighten: set boolean
      - conditions: "{{ trigger.id == 'brighten_hold' }}"
        sequence:
      # Release brighten: unset booleans (mirrors your original behavior)
      - conditions: "{{ trigger.id == 'brighten_release' }}"
        sequence:
          - service: input_boolean.turn_off
              entity_id:
                - !input brighten_boolean
                - !input dim_boolean
      # Hold to dim: set boolean
      - conditions: "{{ trigger.id == 'dim_hold' }}"
        sequence:
      # Release dim: unset boolean
      - conditions: "{{ trigger.id == 'dim_release' }}"
        sequence:
      # Instant 100%
      - conditions: "{{ trigger.id == 'instant_bright' }}"
        sequence:
          - service: light.turn_on
              brightness_pct: 100
              transition: 1
      # Instant 5%
      - conditions: "{{ trigger.id == 'instant_dim' }}"
        sequence:
              brightness_pct: 5
              transition: 1
      # Brighten loop while boolean stays on
      - conditions: "{{ trigger.id == 'brighten_loop' }}"
        sequence:
          - repeat:
              while:
                - condition: state
                  state: 'on'
              sequence:
                    brightness_step: !input step_size
                - delay:
                    milliseconds: !input tick_ms
      # Dim loop while boolean stays on
      - conditions: "{{ trigger.id == 'dim_loop' }}"
        sequence:
          - repeat:
              while:
                - condition: state
                  state: 'on'
              sequence:
                    brightness_step: "{{ (0 - (step_size | int)) }}"
                - delay:
I’ve moved the blueprint to new action events for Z2M.
  • Selector is now event domain only
  • Command is constructed with button and event_type attributes
blueprint:
  description: "Tested with Philips Hue Smart Wireless Dimmer Switch V2 (929002398602).
  domain: automation
  input:
    action_sensor:
      description: Zigbee2mqtt Hue Dimmer action
      selector:
        entity:
          integration: mqtt
          domain:
          - event
          multiple: false
          reorder: false
      description: Input Text used to store the last event fired by the controller.
      default: ''
      selector:
        entity:
          domain:
          - input_text
          multiple: false
          reorder: false
    on_press:
      default: []
      selector:
        action: {}
    on_press_release:
      default: []
      selector:
        action: {}
    on_hold:
      default: []
      selector:
        action: {}
    on_hold_once:
      default: []
      selector:
        action: {}
    on_hold_release:
      default: []
      selector:
        action: {}
    up_press:
      default: []
      selector:
        action: {}
    up_press_release:
      default: []
      selector:
        action: {}
    up_hold:
      default: []
      selector:
        action: {}
    up_hold_once:
      default: []
      selector:
        action: {}
    up_hold_release:
      default: []
      selector:
        action: {}
    down_press:
      default: []
      selector:
        action: {}
    down_press_release:
      default: []
      selector:
        action: {}
    down_hold:
      default: []
      selector:
        action: {}
    down_hold_once:
      default: []
      selector:
        action: {}
    down_hold_release:
      default: []
      selector:
        action: {}
    off_press:
      default: []
      selector:
        action: {}
    off_press_release:
      default: []
      selector:
        action: {}
    off_hold:
      default: []
      selector:
        action: {}
    off_hold_once:
      default: []
      selector:
        action: {}
    off_hold_release:
      default: []
      selector:
        action: {}
mode: restart
- platform: event
  event_type: state_changed
  event_data:
    entity_id: !input action_sensor
condition:
  value_template: '{{ trigger.event.data.new_state.attributes.event_type not in ("", "None", "unknown")
- variables:
    command: '{{ trigger.event.data.new_state.attributes.button | string + "_" + trigger.event.data.new_state.attributes.event_type | string }}'
    prev_command: '{{ states(helper_last_controller_event) }}'
    value: '{{ command }}'
- choose:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
- choose:
  - conditions:
  - conditions:
  - conditions:
  - conditions:
I updated my original blueprint to work without legacy mode enabled and also added a picker filtered by device type so that only proper switches are suggested.
