Blueprint name: Hue Dimmer with Zigbee2MQTT
Requirements
- Philips Hue Dimmer Switch 929002398602
- Zigbee2MQTT
- MQTT
Description:
Purpose of this automation is to control lights with a Philips Hue Dimmer Switch via a Zigbee2MQTT bridge.
- There is no need for helpers or other automation. (No extra entities)
- Dimming should be smooth and not jumpy. (No loops)
- Does not rely on any known legacy solutions (No need for Zigbee2MQTT enable Home Assistant Legacy Sensor)
Challenge?
You need to look up the MQTT Topics for your Dimmer Switch and target light yourself. You can find them in the Zigbee2MQTT.
