I just upgraded to the lastest Core and philipse hue integration stopped working alltorgether. I removed the integration and add it again, but couldnt. Here is the error I am getting
Logger: homeassistant.components.hue.bridge
Source: components/hue/bridge.py:75
Integration: Philips Hue ([documentation](https://www.home-assistant.io/integrations/hue), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+hue%22))
First occurred: 12:25:43 PM (2 occurrences)
Last logged: 12:32:58 PM
Unknown error connecting to Hue bridge
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/components/hue/bridge.py", line 75, in async_initialize_bridge await self.api.initialize() File "/usr/local/lib/python3.9/site-packages/aiohue/v2/__init__.py", line 104, in initialize await self.fetch_full_state() File "/usr/local/lib/python3.9/site-packages/aiohue/v2/__init__.py", line 242, in fetch_full_state await asyncio.gather( File "/usr/local/lib/python3.9/site-packages/aiohue/v2/controllers/base.py", line 312, in initialize await resource_control.initialize(initial_data) File "/usr/local/lib/python3.9/site-packages/aiohue/v2/controllers/base.py", line 80, in initialize resource: CLIPResource = dataclass_from_dict(self.item_cls, item) File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 206, in dataclass_from_dict **{ File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 207, in <dictcomp> field.name: _parse_value( File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 144, in _parse_value return dataclass_from_dict(value_type, value) File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 206, in dataclass_from_dict **{ File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 207, in <dictcomp> field.name: _parse_value( File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 147, in _parse_value return [ File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 148, in <listcomp> _parse_value(name, subval, get_args(value_type)[0]) File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 144, in _parse_value return dataclass_from_dict(value_type, value) File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 206, in dataclass_from_dict **{ File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 207, in <dictcomp> field.name: _parse_value( File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 147, in _parse_value return [ File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 148, in <listcomp> _parse_value(name, subval, get_args(value_type)[0]) File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 144, in _parse_value return dataclass_from_dict(value_type, value) File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 206, in dataclass_from_dict **{ File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 207, in <dictcomp> field.name: _parse_value( File "/usr/local/lib/python3.9/site-packages/aiohue/util.py", line 184, in _parse_value raise TypeError( TypeError: Value 1 of type <class 'int'> is invalid for Position.y, expected value of type <class 'float'>
