Philips hue integration for LK Wiser
Hi Home Assistant users,
I live in Denmark where we have a special electrical socket standard that is smaller than the rest of Europe. Therefore the only switches that fit are made by Schneider Electric owned LK.
I have bought their dimmer switch which has a Zigbee integration. The issue is that the switches are not fully zigbee compliant and therefore they can be turned on and dimmed but not turned off with a Philips Hue bridge. The issue is described here: LK Fuga Wiser Wireless Dimmer hands-on | Jacob Laursen's techblog
Is there a way to implement a fix/workaround for this in Home Assistant as has been done in this link (LK Fuga Wiser Wireless Dimmer hands-on | Jacob Laursen's techblog) for OpenHab?
I use Deconz (with Conbee II)
I had to retry many time to pair it (problem I see with other devices) but once added to Deconz it works like any other dimmer switch.
This is my automation for my kitchen
- id: 'Kitchen_Switch'
  alias: 'Kitchen Switch'
  initial_state: 'on'
  mode: queued
  max_exceeded: silent
    - platform: event
      event_type: deconz_event
      event_data:
    - choose:
      # Normal ON dimmed
      - conditions:
          - condition: template
            value_template: "{{ trigger.event.data.event == 1002 }}"
        sequence:
          - service: scene.turn_on
            entity_id: scene.kitchen_normal
      # Long press full brightness
      - conditions:
            value_template: "{{ trigger.event.data.event == 1001 }}"
        sequence:
          - service: light.turn_on
              entity_id:
                - light.kitchen
              brightness_pct: 100
      # Increase
      - conditions:
            value_template: "{{ trigger.event.data.event == 3001 }}"
        sequence:
          - service: deconz.configure
              entity: light.kitchen
              field: "/action"
              data: {"bri_inc":254, "transitiontime":50}
      # Decrease
      - conditions:
            value_template: "{{ trigger.event.data.event == 4001 }}"
        sequence:
              field: "/action"
              data: {"bri_inc":-254, "transitiontime":50}
      # Stop increase/decrease
      - conditions:
            value_template: "{{ trigger.event.data.event in ( 3003, 4003 ) }}"
        sequence:
              field: "/action"
              data: {"bri_inc":0}
      # Off
      - conditions:
            value_template: "{{ trigger.event.data.event == 2002 }}"
        sequence:
          - service: light.turn_off
              entity_id:
                - light.kitchen
      #default:
