Philips Hue Par38
Has anyone connected Philips Hue model 577361 Par38 Spot Lights directly to Home Assistant using a Zigbee USB adapter (via ZHA or Zigbee2MQTT) without needing a Hue Bridge?
yeah those work without the bridge. 577361 is just a zigbee par38.
reset it first. power 5 times, on about 5s off about 5s, or a hue dimmer held next to it. then put zha or z2m in join and pair. outdoor ones flake on first join if the stick is across the house, pull it closer once then move it back.
dont add the hue integration if youre not using the bridge at all. zha/z2m is the whole point.
