Philips Hue Scene Name
Is it possible to find out the name of the scene which is used for the lights and show it on the UI?
Hello froggi1930, welcome to the forums!
I played around with something like this once (here for a Mushroom Template Card, but a Markdown Card works too). Simply copy the code qnd paste it into Developer Tools —> Template:
type: custom:mushroom-template-card
entity: ''
primary: |-
  {% set x = ( states.scene
  |selectattr('entity_id', 'search', 'anrichte|lounge|wohnzimmer')
  |sort(attribute='last_changed', reverse=true) )[0:1]
  |map(attribute='entity_id')
  |join
  {{ 'Szene ' ~ state_attr(x, 'name') if
  states('light.'~area_name(x)|slugify)
  == 'on' else 'keine Szene aktiv' }}
secondary: |-
  |join
  {% set l = 'light.'~area_name(x)|slugify %}
  {% set b = '%0.f'|format(state_attr(l, 'brightness')/255*100|int(0)) if
  states(l) == 'on' else '0' %}
  {{ area_name(x) ~ ' | Helligkeit: ' ~ b ~ ' %' if states(l) == 'on' else ' '}}
icon: mdi:palette
icon_color: |-
  |join
  {% set rgb = state_attr(l, 'rgb_color') %}
  {{ '#%02x%02x%02x' % rgb if states(l) == 'on' else 'disabled' }}
I believe there is also a Hue-Like card you can use but it will require installing via HACS.
See
Werde ich am Wochenende ausprobieren. Im Moment bin ich noch blutiger Anfänger… habe vorher veiel Jahre mit ioBroker gearbeitet und muss jetzt erst einmal das neue Konzept verstehen :slight_smile:
Looks very good… at least it is the fast approach to my p :upside_down_face:roblem
yay, first time i’ve been able to help someone on here! (i’m also new to the community)
people have helped me a ton so i’m glad to pay it forward in a small way!
i’m considering installing those cards myself btw but i’m getting a more basic version of that functionality in a way that i find more aesthetically pleasing… we shall see!
