If the tap dial supports it in ZHA, it should only be a matter of replacing command == 'step_with_on_off'
with command == 'step'
in the blueprint.
Both are valid zigbee commands, but it would depend on the device cluster and whether it was implemented with the quirks.
Sorry for the late reply, I’m using the following:
So far it works great, it can control 4 different lightgroups and also dim them separately!!
Thank you for your template, I mixed your and @timothi ’s and created one that uses all 4 buttons and mqtt-action sensor (not listening to mqtt topic)
For anyone that stubles upon this: Create a new folder/file in your blueprints-folder and add this, reload and its ready to go
blueprint:
name: Zigbee2MQTT - Hue Tap Dail Switch
description: 'Control lights with a Philips Hue Tap Switch. Use the four buttons
to control up to four light(s) with an on/off toggle. The dial can be used to
dim the most recently used light.
example value zigbee2mqtt/0x001788010d7d3cac/action
source https://community.home-assistant.io/t/philips-hue-tap-dial-switch-zha/446636/114
domain: automation
input:
button_sensor:
name: Philips Hue Tap dial switch sensor entity
description: Sensor for Philips Hue Tap dial switch to use (Use sensor with
entity_id ends with _action)
selector:
entity:
domain:
- sensor
multiple: false
remote_button_1_single_press:
name: Button 1 Single Press
description: The light(s) to control with first button
selector:
entity:
- domain:
- light
remote_button_2_single_press:
name: Button 2 Single Press
description: The light(s) to control with second button
selector:
entity:
- domain:
- light
remote_button_3_single_press:
name: Button 3 Single Press
description: The light(s) to control with third button
selector:
entity:
- domain:
- light
remote_button_4_single_press:
name: Button 4 Single Press
description: The light(s) to control with fourth button
selector:
entity:
- domain:
- light
current_button:
name: (OPTIONAL) Current Light
description: Text helper to track the current light to dim. Set for the dimmer
controls to change which light they are controlling according to the last
one turned on.
default:
selector:
entity:
domain:
- input_text
multiple: false
dim_scale:
description: Scale factor for the dimming. This value will be multiplied by
the value given from the dial. So lower number, more gradual dimming. Larger
number, faster dimming.
default: 3.0
selector:
number:
min: 0.0
max: 5.0
step: 0.01
mode: slider
dim_time:
description: How long it takes to dim one step
default: 0.5
selector:
number:
min: 0.1
max: 1.0
step: 0.01
mode: slider
source_url: https://github.com/AnderssonPeter/HomeAssistantBlueprints/blob/65f08a396a2d6e259b6b5f3a40e9b51a48ca0b8c/HueTapDailSwitch.yaml
mode: restart
max_exceeded: silent
variables:
remote_button_1_single_press: !input remote_button_1_single_press
remote_button_2_single_press: !input remote_button_2_single_press
remote_button_3_single_press: !input remote_button_3_single_press
remote_button_4_single_press: !input remote_button_4_single_press
current_button: !input current_button
dim_scale: !input dim_scale
lights:
- platform: state
entity_id: !input button_sensor
to: button_1_press
- platform: state
to: button_2_press
- platform: state
to: button_3_press
- platform: state
to: button_4_press
- platform: state
to: dial_rotate_left_step
- platform: state
to: dial_rotate_left_slow
- platform: state
to: dial_rotate_left_fast
- platform: state
to: dial_rotate_right_step
- platform: state
to: dial_rotate_right_slow
- platform: state
to: dial_rotate_right_fast
- variables:
action: '{{ trigger.to_state.state }}'
- choose:
- conditions: '{{ action == ''button_1_press'' }}'
sequence:
- service: light.toggle
target: !input remote_button_1_single_press
- choose:
- conditions: '{{ current_button != none }}'
sequence:
- service: input_text.set_value
entity_id: !input current_button
value: remote_button_1_single_press
- conditions: '{{ action == ''button_2_press'' }}'
sequence:
target: !input remote_button_2_single_press
- choose:
sequence:
value: remote_button_2_single_press
- conditions: '{{ action == ''button_3_press'' }}'
sequence:
target: !input remote_button_3_single_press
- choose:
sequence:
value: remote_button_3_single_press
- conditions: '{{ action == ''button_4_press'' }}'
sequence:
target: !input remote_button_4_single_press
- choose:
sequence:
value: remote_button_4_single_press
- conditions:
- '{{ action == ''dial_rotate_left_step'' }}'
sequence:
- choose:
sequence:
- service: light.turn_on
target: '{{ lights[states(current_button)] }}'
brightness_step_pct: '{{ -dim_scale }}'
transition: !input dim_time
default:
- conditions:
- '{{ action == ''dial_rotate_right_step'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ dim_scale }}'
default:
- conditions:
- '{{ action == ''dial_rotate_left_slow'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ -dim_scale * 2 }}'
default:
- conditions:
- '{{ action == ''dial_rotate_right_slow'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ dim_scale * 2 }}'
default:
- conditions:
- '{{ action == ''dial_rotate_left_fast'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ -dim_scale * 5 }}'
default:
- conditions:
- '{{ action == ''dial_rotate_right_fast'' }}'
sequence:
- choose:
sequence:
brightness_step_pct: '{{ dim_scale * 5 }}'
default:
Thank you for your work.
Could you please give me a hint how to set up the Text Helper correctly?
If not set up a Text Helper, the dial only works for the lamp on the 1st button (generally all 4 lamps are dimmable).
If set up, nothing happens when turning the dial.
What I did:
1st I set up a Text Helper (as there wasn’t any information here, I took a template from another website):
Then I just choosed it in your blueprint by the dropdown menu:
So what to do to set it up correctly please?
apollo1220
(Jeremy Fisher)
September 11, 2024, 12:19pm
145
The regex that you setup would be preventing it from storing the value it needs to store. Remove that and it should work fine.
Thank you for trying to help!
But no joy, I’m sorry. Emptied the “Regex pattern” field, saved, started HA new, but no change.
What I wonder about: How does the helper know the last input from the Hue Tap? Where is the input? Maybe I missed an important requirement?
Edit:
Found a “traces” button and got this:
But where does it miss the id?
Any idea somebody? Any help appreciated
melagodo
(G)
October 31, 2024, 11:24am
148
Is there any way to replicate the original behavior of the dial?
Let’s say I assign a scene to a button that turn on 2 out of 3 lights, the dial only affects the lights that are already on and have no impact on the lights that are off.
I’ve never put anything in here but it only ever adjusts the brightness of the light on button 1, even if it’s off it’ll dial up the brightness and turn it on. Any hints on how to set this up please? Pretend I don’t know yaml or regex!
Schurki
(Schurki)
November 19, 2024, 2:34pm
150
Not exactly original. But I currently combined this script with the other script for the hue dial tab.
blueprint:
name: Philips Tap Dial Switch 4 Lights or Custom (ZHA)
to control up to four light(s) with an on, off or toggle or custom actions.
Supports short releaese, long release and double press, each beheaviour can
configured seperatly.
The dial can be used to dim the most recently used light or call a custom
rotation action for that button.
based on
apollo1220 - https://github.com/apollo1220/blueprints/blob/main/philips_zigbee_dial.yaml
gtunes - https://gist.github.com/gtunes-dev/c87168d84292004e760ce697ba1ae6af'
domain: automation
input:
remote:
name: Philips Hue Tap Switch
selector:
device:
integration: zha
manufacturer: Signify Netherlands B.V.
model: RDM002
This file has been truncated. show original
It’s still work in progress but as workaround you could try to set the lights (for dimming) and then define a custom action that start the scene.
For some reason the dimming is not working in HA for scenes although scenes have all the lights enteties as attribut. One could surely do it in the blueprint but I could not find a quick solution yet and that.
