Philips Hue Wall switch module (RDM001) Push dimmer
The Philips Hue Wall switch module can be difficult to use as a smooth dimmer when paired with a push‑button wall switch. This blueprint provides an easy and reliable way to achieve intuitive dimming behavior using short‑press and long‑press actions.
Features
  • Short press: toggle the light
  • Long press: dim up or down (with automatic boundary correction while holding)
  • Long release: reverse the dimming direction for the next hold
  • Configurable dim step size
  • Configurable transition time
  • Configurable delay between dimming steps
  • Automatic direction switching when brightness reaches a defined threshold
  • Uses an input_number helper to store dimming direction (1 = brighter, -1 = dimmer)
Notes
  • This blueprint requires the Zigbee Home Automation (ZHA) integration.
  • The Signify RDM001 module is supported. For now only single push button.
  • Make sure to select the correct model depending on the type of button(s) you use.
  • More information on how this is done can be found here.
  • You must create an input_number helper beforehand with:
    • min = -1
    • max = 1
    • step = 1
      This helper stores the dimming direction between presses.
