Just got home with a pair of these. I think theyre primarily used for behind TV's but id like to use them for kitchen under cabinet lighting. I initially paired then in Zigbee2MQTT - one went in fine and red the config...the other one went in as an unknown device so i removed it but, it wont let me repair it. Ive tried powering it on and off (id read 5 times in succession) but it still wont repair...ive not got a hue bridge and just using (obviously) home assistant...does anyone else have these...
These... Philips Hue Play White and Colour Ambiance Smart Light Bar Double Pack Base Unit, Entertainment Lighting for TV and Gaming (Works with Alexa, Google Assistant and Apple HomeKit), Black : Amazon.co.uk: Lighting
Thanks for any help anyone can give.
Ill mark it myself as solved....i installed the android app, found them using bluetooth and then ran firmware updates on both of them then reset the problem one from my phone. Now repaired into HA.
Oh the other thing to add is if you find yourself here....the firmware updates look like they go on one after the other - not the latest one only....mine did 3 updates each.
