Philips WIZ?
Is anybody using the Philips WIZ integration/devices?
I’m looking at buying some of their RGB potlights but couldn’t get a clear answer from support about them being completely local or not.
HA documentation states you can toggle on LAN control but I want to see if anybody here is using them and if this is still the case?
Thanks!
Control is local, but I don’t know if they are “completely local.”
Unless things have change, pretty sure you need internet access for initial setup. After setup, I had issues with them going offline when I tried to block the device at the router.
But… I’m not sure that was the actual problem, there were some other things going on at the time and I never went back and re-tested.
