I try to integrate a new Philips Xiaomi bulb directly without gateway.
I checked using ping that the bulb is reachable
I obtained the token using MitoolKit that confirms the ip
My configuration is:
light:
I don’t understand your question: if you add the lamp to your private network at home, it has an IP which belongs to the DHCP range provided by your home router (in my case 172.16.23.x), which is what you need to input in your HA.
It seems that this link is if I have a gateway. This is what I did when I had the gateway installed, I retrieved the token and the lamp integration worked. But now that I removed the gateway, it does not work anymore. But I can still see and control the light from Mi Home.
To come back to the link you sent, it asks me to go into my gateway settings which I don’t have anymore.
I am sorry, I am very noob in this. What I did is link the light to my wifi using the Mi Home app. So now I can see on my router’s page the light IP address which is 192.168.0.18. How to find the other IP address?
Thank you for your explanations. So I checked, the token hasn’t changed even after removing the gateway. The IP is still good. So I do not need to change my integration. But I still can’t see the light. The IP is good as I can see it through nmap device tracker being home.
