Phnix fan coil modbus ESP integration
Hi to everyone
I have managed to integrate my Phnix fancoil to home assistant via it’s MODbus and ESPHome wirelessly.
You will need
  1. ESP8266 or ESP32 board (Wemos D1 mini is the one I use here.)
  2. RS485/TTL converter
  3. a 120Ω resistor conected in parallel to terminate the modbus side. (my RS485/TTL converter had one onboard).
Basic usage and setup of ESP boards and connections are not included in this post, I suppose that you will get around it from other sources or you already know a few bits.
The reason I am posting it is for others to avoid going through the same as me writing the code.
Keep in mind I am not an expert and there may be better ways, but thats how I did it and it works absolutely perfect.
Make sure to change accordignly:
ESP board type.
Naming of the entitites.
And any other that is personal info like replacing the wifi and SSID with your own wifi’s credentials.
Here is the Code that you need.
esphome:
  friendly_name: phnix-modbus-controller
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "**************************************"
ota:
  - platform: esphome
    password: "************************"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Phnix-Modbus-Controller"
    password: "12345678"
captive_portal:
web_server:
  port: 80
uart:
  tx_pin: GPIO13
  rx_pin: GPIO12
  baud_rate: 9600
  stop_bits: 1
modbus:
  send_wait_time: 100ms
modbus_controller:
  - id: phnix
    ## the Modbus device addr
    address: 15
    modbus_id: phnix_fancoil
    setup_priority: -10
    update_interval: 15s
text_sensor:
    name: "Living Room Fancoil Mode text"
    name: "Living Room Fan Speed"
number:
  - platform: modbus_controller
    modbus_controller_id: phnix
    name: "Living Room Fancoil On/Off"
    address: 28301
    register_type: holding
    value_type: U_WORD
    use_write_multiple: True
    entity_category: config
    min_value: 0
    max_value: 1
    step: 1
    mode: slider
    icon: "mdi:toggle-switch"
    name: "Living Room Cool Temperature"
    address: 28310
    value_type: S_WORD
    min_value: 16
    max_value: 30
    step: 1
    multiply: 10
    mode: slider
    name: "Living Room Heat Temperature"
    address: 28311
    value_type: S_WORD
    min_value: 16
    max_value: 30
    step: 1
    multiply: 10
    mode: slider
    name: "Living Room Set Fan Speed"
    address: 28303
    value_type: S_WORD
    min_value: 2
    max_value: 6
    step: 1
    mode: slider
    name: "Living Room Mode Set"
    address: 28302
    value_type: S_WORD
    min_value: 0
    max_value: 4
    step: 1
    mode: slider
    name: Living Room Fancoil Mode
    address: 28302
    value_type: U_WORD
    #entity_category: config
    on_value:
      then:
        - lambda: |-
            int state = id(living_room_fancoil_mode).state;
            std::string text;
            if (state == 0) {
              text = "Auto";
            } else if (state == 1) {
              text = "Cooling";
            } else if (state == 2) {
              text = "Dehumidifier";
            } else if (state == 3) {
              text = "Fan Only";
            } else if (state == 4) {
              text = "Heating";
            } else {
              text = "UNKNOWN";
            id(living_room_fancoil_mode_text).publish_state(text);
    name: Living Room Fan Speed
    address: 46803
    register_type: read
    value_type: U_WORD
    on_value:
      then:
        - lambda: |-
            int state = id(living_room_fan_speed).state;
            std::string text;
            if (state == 0) {
              text = "Off";
              text = "Ultra Low";
              text = "Low";
              text = "Medium";
              text = "High";
            } else if (state == 5) {
              text = "Top Speed";
            } else if (state == 6) {
              text = "Auto";
            } else {
              text = "UNKNOWN";
            id(living_room_fan_speed_text).publish_state(text);
    name: "Living Room Fancoil Air Temperature"
    address: 46801
    unit_of_measurement: "°C"
    register_type: read
    value_type: S_WORD
    accuracy_decimals: 0
    filters:
    - multiply: 0.1
    name: "Living Room Fancoil Coil Temperature"
    address: 46802
    register_type: read
    value_type: S_WORD
    filters:
    - multiply: 0.1
    name: "Living Room Fan RPM"
    address: 46804
    unit_of_measurement: "RPM"
    register_type: read
    value_type: S_WORD
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
    entity_category: "diagnostic"
  - platform: copy # Reports the WiFi signal strength in %
    source_id: wifi_signal_db
    name: "WiFi Signal Percent"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "Signal %"
switch:
  address: 28301
For any questions fell free to reply.
Attached the PHNIX modbus info coming from the main dealer in Greece. (extremely helpful.)
nice work @blacknass ! I’ve done the same with some EW11 (https://www.aliexpress.com/i/32916950283.html) and Modbus integration, so I’ve made a thermostat for each fan coil. Works like a charm!
