Phoscon Deconz update
Hi all,
Has anyone else experienced an issue when updating the deconz stick firmware through phoscon, where the update completes successfully (reports as such), but then the message reverts back to “A new firmware version is available”?
Screenshots of process:
“A new firmware version is available”? message is visible, so i click the button to “Update to 26660700”
“Update is running” after i click the button to update.
“Update is finished” i presume successfully due to the tick
New version is displayed, with the message “Version is up to date”
The a few seconds later, without any interaction, the message reverts to “A new firmware version is available”?
Any thoughts?
Are you running deconz as an add-on or in a docker container? If so, you are not anle to update the firmware through the UI (or at least it was not possible in the past).
thank you…
yes i am running it as the add-on through Supervisor > Addons.
i guess i will update manually… thanks
