i have a PTZ foscam which is exposed in a picture-elements card (similar to what the documentation also offers). It works as expected - the lovelace card shows a live stream from the camera and the buttons move it around. I just can’t figure out how to make a bigger pop-up of the camera stream when i click the image in the card (i want basically the same behaviour as when clicking the picture-entity).
does anybody have a clue how to achieve this?
I am after exactly the same information. Did you get it going?
Not optimal, but some kind of workaround:
- Create a new view (tab) in badge mode, e.g. “camera door”
- Add camera as first element. Should now be full width
- for the original picture entity card change tap action to navigate and path to the newly created tab (e.g. /lovelace/camera-door)
I use browser_mod to do this, using the pop up cards
Hi there, thanks for this tip, would you mind sharing your config to the tap action on the camera stream? I can’t seem to get it to function but think I must be adding it to the wrong place in the UI yaml.
type: picture-elements
image: camera.name_camera
camera_image: camera.name_camera
camera_view: live
elements:
- type: image
entity: camera.name_camera
camera_view: live
style:
top: 50%
left: 50%
width: 100%
opacity: 0%
