Hi, I have a Firepad that I use as a wall mounted dashboard since many years. The core element is a picture elements card that shows the time next to many other things. Recently, I noticed that the time does not update anymore after about 30-60 mins after I reload the page. I experimented to narrow down the problem and found the following:
If you create a new dashboard as a panel, add a picture elements card and add the time on it, you should find that after 30-60 mins the time doesn’t update anymore. If I just use the clock without the picture elements card on the panel, I don’t have that issue.
Is this issue known? Can somebody reproduce as well?
Thank you community!
