I’m using a Picture Elements card and have an image I want to saturate depending on the brightness level of a light.
I have tried this but doesn’t work, is it even possible ?
If I replace the template with a number between 0 and 1 it works fine.
The template works in the Template Editor.
did you find a way.
i tried using css styles at the top of the picture-element, which works fine for color settings but i cant find a way to set saturate and opacity with a dynamic value
