Picture-elements state-label value rounding
Is there a way to round a value directly on a state-label of a picture-element without having to create a template on the yaml file for each sensor ?
Have you considered adjusting the sensors Display precision?
You are right, I missed this enhancement on HA.
Thankls
Where do you edit the default precision values?
Go to devices and Service, select the entity tab, then the entity. Click on the Settings gear
and then you will see this
This I saw and I could modify for ONE sensor.
But I have a lot of sensors, when I look an unchanged it is telling default (20.36),
this is suggesting me that there is a default value somewhere where I could globally change for all temperature sensors to 20.3.
I am unaware of a method which doesn’t means it’s not possible. Your suggestion may be worth a creating a Feature Request.
