Piggybacking rotary encoder on thermostat
I tried linking my central heating in using EMS-ESP, but the thermostat was incompatible.
The incremental rotary encoder in the thermostat uses quadrature encoding at ca. 3V which I thought would be straightforward enough to mimic using an ESP8266. I’ve attached connections to the relevant terminals of the encoder but have not managed to get functional code working yet for the ESP, so have not connected it yet. I’m relatively new to coding so may be making rookie mistakes…
This is my current code:
esphome:
  friendly_name: ch-thermostat
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "myKey="
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-10453A"
    password: "myPassword"
captive_portal:
#use GPIO4 and GPIO5 as no conflicts at boot
#read
# binary_sensor:
#   - platform: gpio
#     pin: GPIO5
#     id: read_a
#   - platform: gpio
#     pin: GPIO4
#     id: read_b
#write
switch:
  - platform: gpio
    pin: GPIO5
    restore_mode: DISABLED
  - platform: gpio
    pin: GPIO4
button:
    on_press:
      - switch.toggle: encoder_a
      - delay: 50ms
      - switch.toggle: encoder_b
      - delay: 50ms
    on_press:
      - delay: 50ms
      - delay: 50ms
Is the state of a GPIO switch stored somewhere, or is it actually checked first?
If the former, does it also need to be a binary sensor to check?
I’ve also tried this, but am getting complaints about syntax errors:
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
api:
  encryption:
    key: "myKey="
ota:
wifi:
  ap:
captive_portal:
#read
binary_sensor:
  - platform: gpio
    pin: GPIO5
  - platform: gpio
    pin: GPIO4
#write
switch:
  - platform: gpio
    pin: GPIO5
  - platform: gpio
    pin: GPIO4
button:
    on_press:
      if:
        binary_sensor.is_on: read_a
        then:
         - switch.turn_off: encoder_a
         - delay: 50ms
        else:
          - switch.turn_on: encoder_a
          - delay: 50ms
        if:
          binary_sensor.is_on: read_b
          then:
          - switch.turn_off: encoder_b
          - delay: 50ms
          else:
          - switch.turn_on: encoder_b
          - delay: 50ms
    on_press:
      if:
        then:
         - delay: 50ms
        else:
          - delay: 50ms
        if:
          then:
          - delay: 50ms
          else:
          - delay: 50ms
Any pointers very gratefully received! TIA
This? Rotary Encoder Sensor — ESPHome
Thanks - but as I understand it, that’s to read a physical rotary encoder in operation.
I want to mimic one in software, but believe I also need to take into consideration the current output states of the physical one it’s connected across for it to be effective.
E.g. if I set encoder_a to high, then encoder_b to high, if encoder_a is already high it looks like encoder_b is the first signal, indicating a turn in the opposite direction!
