ebnerjoh
(Johannes Ebner)
June 27, 2020, 6:29am
1
I added my Pi-Hole to Home Assistant and have also configured the API-Key.
But when I try to disable the service I am getting the following error:
2020-06-27 08:25:15 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.22632414451088] Error handling message: expected dict for dictionary value @ data['service_data']. Got 3600
Br,
Johannes
Recte
June 28, 2020, 10:11am
2
I believe the duration in Service Data should be added as:
duration: '01:00:00'
not in seconds.
ebnerjoh
(Johannes Ebner)
June 30, 2020, 4:25am
3
How can I call this service via the Frontend? Can I configure a button, which activates a predefined duration and deactivting again or do I need to do a workaround via script/automation?
pi_hole.disable with dution 01:00:00
pi_hole.enable
Recte
June 30, 2020, 9:53am
4
That is no work-around, that is how it works
Create an automation or script that gets kicked off by pressing a button
