Ping sensor and autmations
Hi
I try to send a email, when I ping a switch (meens power gone in the house)
binary_sensor:
- platform: ping
  host: 192.168.13.11
  count: 2
  scan_interval: 30
Automations:
- id: "ping_sw_stue"
  alias: Ping sw stue
    platform: state
    entity_id: binary_sensor.sw_stue
    to: 'off'
    - service: script.test_notification_03
scripts:
test_notification_03:
  alias: Test Notification 03
  sequence:
  - service: notify.eh_gmail
      title: alert
      message: This is a test notification 03!
test_notification_03 work fine, it send the email
when I press trigger under automation its work
hassio-03
But if power off the switch, it dont send the email.
What do I wrong?
I have googlet a lot, but I cant find the answer:cry:
BG Erling
If you turn off the Sensor from Power, the sensor does not have the entity off, look in the status which status the sensor has. Probably unaviable and not off
Check too that the automation is turned on
Automation is on and the ping sensor say Disconnected / Connected, but I have try that too, with no luck.
